Below is a code snippet/////////////////////////////////
$map_path="C:/Program Files/ms4w/apps/wms/";
$map = ms_newMapObj($map_path."ICWMS2.map");
$map->setextent(586892.5,339611.094,593679.063,346206.156);
$image=$map->draw();
$layer = $map->getLayerByName('PARCELS');
$status = $layer->open();
$status = $layer->whichShapes($map->extent);
while ($shape = $layer->nextShape())
echo $shape->toWkt();
$layer->close();
$image_url=$image->saveWebImage();
echo(" <IMG SRC=$image_url >");
Below is the layer in the map file//////////////////
LAYER
TYPE POLYGON
STATUS ON
NAME "PARCELS"
FILTERITEM "PIN"
FILTER "84-035-40-001-00"
DATA "Par.shp"
CLASS
STYLE
OUTLINECOLOR 0 0 255
SIZE 4
END
END
END
If I remove the FILTER on the layer, the whichshapes code works correctly and returns all the shapes within the extent.
Let me know what you think.
Thanks.
----- Original Message ----
To: mapserver-users at lists.osgeo.org; jjschlafley at yahoo.com
Sent: Thursday, July 3, 2008 10:00:19 AM
Subject: Re: [mapserver-users] Mapscript whichshapes attribute query
No, just setting the filter in the mapfile should suffice. Do you have a code snippet?
Steve
>>> "J.J. Schlafley" <jjschlafley at yahoo.com> 07/03/08 8:51 AM >>>
If I have a FILTER and FILTERITEM set in my map file for a layer....when I call a whichshapes on that layer I get zero shapes. Comparatively, if I run a map draw, the FILTER works correctly and draws the shapes that meet the criteria. Do I need to use mapscript to set the filter or something? Thanks
Sent: Wednesday, July 2, 2008 9:29:06 PM
Which shapes applies the layer FILTER definition if it exists. That FILTER must be set prior to calling whichshapes.
Steve
>>> "J.J. Schlafley" <jjschlafley at yahoo.com> 07/02/08 12:22 PM >>>
The mapscript documentation for the method (LayerObj) whichshapes claims you can quote: "Performs a spatial, and optionally an attribute based feature search." How and where is the attribute based search query included in this method?
JJ
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080703/35b81e29/attachment.htm>
