[mapserver-users] Rotating map makes layer disappear
Matthias Buchs
matthias.buchs at ruch.ch
Thu Jul 10 10:09:33 EDT 2008
Hello Flavio,
Thank you for your answer! I had already a projection defined for all layers.
However, I tried yours too, but with the same result: All layers are drawn
correctly (incl. rotation) except the single one, which is not drawn. The
layer definition looks as follows:
LAYER
NAME "No_parc"
TYPE ANNOTATION
MAXSCALE 2000
CONNECTIONTYPE OGR
CONNECTION "Noparc.TAB"
STATUS ON
STYLEITEM "AUTO"
CLASS
END
PROJECTION
"init=epsg:21781"
END
END
The beginning of the ogrinfo output looks as follows:
INFO: Open of `Noparc.TAB'
using driver `MapInfo File' successful.
Layer name: Noparc
Geometry: Point
Feature Count: 603
Extent: (576093.803015, 184574.105015) - (579583.217242, 186778.565010)
Layer SRS WKT:
LOCAL_CS["Nonearth",
UNIT["Meter",1.0]]
OGRFeature(Noparc):1
ID (Integer) = 0
Style = LABEL(t:"518",a:0.000000,s:3.253910g,c:#ff0000,p:1,f:"Arial")
POINT (577595.99998399999 186382.12960400002)
What else could it be?
Regards
Matthias
