[mapserver-users] PostGIS connecton error
Steve White
steve at online-archaeology.co.uk
Tue Jul 8 14:07:17 EDT 2008
After much fiddling around I managed to install PostgreSQL with PostGIS and
set up a connection in a layer like this:
MAP
NAME Test
STATUS ON
UNITS METERS
SHAPEPATH "C:\Inetpub\scripts\data\"
IMAGECOLOR 0 255 255
SIZE 400 400
DEBUG ON
IMAGETYPE PNG
EXTENT -4.35 56.14 -3.23
56.91
DATAPATTERN '.*'
WEB
METADATA
"wms_title" "Test MS"
"wms_onlineresource" "http://localhost/scripts/mapserv.exe
<http://localhost/scripts/mapserv.exe&> &"
"wms_srs" "EPSG:4326 EPSG:54004
EPSG:27700"
"wms_feature_info_mime_type" "text/html"
END
IMAGEPATH "C:\Inetpub\wwwroot\tmp\"
IMAGEURL "C:\Inetpub\wwwroot\tmp\"
LOG
"C:\Inetpub\wwwroot\tmp\mapserver.log"
TEMPLATE
"C:\Inetpub\wwwroot\OAMap\templates\template.html"
EMPTY
END
#QUERYMAP
# STATUS ON
# STYLE HILITE
# COLOR 255 255 0
# SIZE 10
#END
PROJECTION
"init=epsg:4326"
END
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
LAYER
NAME
"test"
CONNECTIONTYPE
postgis
CONNECTION "user=oa
password=******* dbname=OA"
METADATA
"wms_title" "test"
"gml_include_items" "all"
"wms_include_items" "all"
END
TYPE
POINT
DATA
"the_geom from (SELECT the_geom from medievalbattlefieldstable WHERE
itemname LIKE '%Lewes%') as foo using unique gid using SRID=4326"
STATUS
ON
DUMP TRUE
PROJECTION
"init=epsg:4326"
END
CLASS
TEMPLATE
SYMBOL "circle"
SIZE 10
COLOR 255 0 255
END
END #end of layer
END # end of mapfile
Here's the exception from MapServer:
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'test'.
prepare_database(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from
(SELECT the_geom from medievalbattlefieldstable WHERE itemname LIKE
'%Lewes%') as foo WHERE the_geom &&
setSRID('BOX3D(-5.625 52.4827802220782,0 55.7765730186677)'::BOX3D,
4326 )'
Postgresql reports the error as 'ERROR: column "gid" does not
exist
LINE 1:
...inary(force_collection(force_2d(the_geom)),'NDR'),gid::text ...
More Help:
Error with POSTGIS data variable. You specified 'check your .map
file'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (sub query) as foo using unique column name
using SRID=srid#'
Make sure you put in the 'using unique column name' and 'using
SRID=#' clauses in.
For more help, please see http://postgis.refractions.net/documentation/
Mappostgis.c - version of Jan 23/2004.
</ServiceException>
</ServiceExceptionReport>
As you can see, it says column 'gid' does not exist. This doesn't make any
sense to me because I can see a gid column in my table and it has been set
up as the PK. If I take out the sub query and just run it in the Query tool
using pgAdmin III it works!
SELECT the_geom from medievalbattlefieldstable WHERE itemname LIKE '%Lewes%'
Can anyone give me some clues what's going on here?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080708/c86e5656/attachment-0001.html
