[mapserver-users] New limitations with mapserver 5 CGI
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jul 10 19:26:12 EDT 2008
Steve L,
There was some discussion about using metadata regex's to validate
changes via the URL. Did this not go into play? I thought we were going
to do something like:
1) default it is restricted or disabled
2) if metadata "validate_some_parameter" "some_regex" then allow those
changes that validate.
Then if someone wanted to unrestrict it they could use a regex "/./" to
allow anything or set it to whatever.
-Steve W
Steve Lime wrote:
> Hi Graeme: Comments inline... I definitely underestimated the impacts
> of those changes. Anyway...
>>>> On 7/9/2008 at 11:23 PM, in message
> <1215663787.2513.112.camel at bongolx.ringo.net>, Graeme Watmuff
> <gwatmuff at geographicweb.com.au> wrote:
>> It has become apparent through some frustrating moments of trial
>> and error that many of the mapfile variables that were changeable
>> via URL with mapserver 4.10.x CGI seem no longer changeable with
>> v5.x or 5.2.x. There is a hint from the docs that this is because
>> of security concerns? Our java apps don't allow web users to
>> directly interact with the CGI, so security doesn't seem so
>> important in our case.
> Allowing unaltered, direct modification of things like FILTERs or
> CONNECTIONS is a potential security risk although I've never run
> across a documented case. Filters are risky because they are passed
> to the underlying data driver which generally trust the contents.
>> Some examples:
>> map_web_metadata='text1' 'text2' map_layerName_filter=<expression>
>> map_layerName_tileindex=<tileindex.shp>
>> map_layerName_data=<datasource>
>> allow changes to the mapfile via URL with mapserver 4.10.x
>> Following the new syntax specified for v5 + I had expected
>> map_web=metadata+"'text1' 'text2'" or maybe
>> map_web_metadata[0]='text1'+'text2',
>> map_layer[layerName]=filter+<expression>,
>> map_layer[layerName]=tileindex+<tileindex.shp>,
>> map_layer[layerName]=data+<datasource>
>> to all perform in the time-honoured way.
> And they don't... If they did you could combine modifications to a
> layer in a single variable:
> map_layer[layerName]=filter+<expression>+tileindex+<tileindex.shp>+data+<datasource>
>> Only 'data' could be changed with this new mapserver 5 syntax. I
>> happened to discover through the change logs that changing
>> tileindex was reinstated for mapserver 5 CGI, but using the old
>> mapserver 4.10 syntax (map_layerName_tileindex)=<tileindex.shp> -
>> not the new mapserver 5 syntax style
>> (map_layer[layerName]=tileindex+<tileindex.shp>).
> Looking at the code, TILEINDEX is not changable via a URL with any
> syntax. The change log references a bug fix to 4.10. The old syntax
> doesn't work at all.
>> mapserv 5 CGI throws an error (Parsing error near (filter)) when
>> the new syntax is used for filter and ignores the old 4.10 filter
>> syntax.
> This is expected. It will fail with an error as opposed to the silent
> failure of versions past.
>> No URL syntax for changing the web object's metadata content
>> appears acceptable to the mapserver 5.
> Correct.
>> I would dearly like to see changing the layer filter via URL
>> restored also to mapserver 5. And the web object's metadata setting
>> functionality too.
> It's possible to customize this behavior by editing maplexer.l and
> recompiling the code. Simply find the keyword you're interested in
> supporting and change the states at which it is valid. So, for
> TILEINDEX:
> <INITIAL>tileindex
> becomes:
> <INITIAL,URL_STRING>tileindex
> Same goes for the other parameters you'd want to activate.
>> Can anyone indicate what mapfile properties are or are not going to
>> be reinstated in mapserver 5 compared to mapserver 4 for change via
>> URL? Obviously this has development ramifications for us when we
>> try to upgrade mapserver.
> If I (or anyone) can think of a way to make this tunable at runtime
> I'd love to talk more about it. The set of parameters supported in
> 5.2 has only changed a little bit since 5.0 based on user input. I
> can't see exposing more without good reason. FILTER in particular is
> worrisome and there is a work around with the runtime substitution
> (e.g. FILTER %someval%). In that example you can pass someval via URL
> but you have to define a validation pattern (a regex) to check it
> against.
>> Alternatively, am I missing something with new mapserver 5 syntax?
> I'm curious if updating maplexer.l to fit your particular needs is
> workable.
>> Graeme Watmuff
> Steve
> _______________________________________________ mapserver-users
> mailing list mapserver-users at lists.osgeo.org
