[mapserver-users] Logging
Anakreon Mentis
anakreon at csd.auth.gr
Mon Jul 14 10:45:34 EDT 2008
Daniel Morissette writes:
> Anakreon Mentis wrote:
> > It says:
> > Premature end of script headers: mapserv
> > Can you tell what this means?
> Most likely cause is a segmentation fault (i.e. complete crash).
> If you just access mapserv with no parameters in the URL then do you get
> the message "No query information to decode. QUERY_STRING is set, but
> empty." as exepcted or does it crash as well?
No. I get the that message
> Perhaps also try running the request that crashes at the command line to
> see if you also get the crash there:
> /path/to/mapserv "QUERY_STRING=map=/path/to/yourmap.map&mode=...&..."
I pass only the path to the map as parameter. I get a segmentation fault
mapserv "QUERY_STRING=map=/home/anakreon/ekby_site/web/gis_files/maps/ekby.map"
> If it crashes, then you'll need to find out where in the code and why...
> can you use 'gdb'? Did you build from source or get prebuilt binaries
> from somewhere? Which version of MapServer did you use before, and now
> after the upgrade?
> Daniel
I have binaries from debian.
Current version is:
cgi-mapserver 5.0.2-3
> Daniel Morissette
> http://www.mapgears.com/
