[mapserver-users] Logging
Anakreon Mentis
anakreon at csd.auth.gr
Mon Jul 14 11:26:35 EDT 2008
Daniel Morissette writes:
> Anakreon Mentis wrote:
> > I pass only the path to the map as parameter. I get a segmentation fault
> > mapserv "QUERY_STRING=map=/home/anakreon/ekby_site/web/gis_files/maps/ekby.map"
> ouch!
> Does it seg fault as well with one of the MapServer demos, for instance
> the one at http://mapserver.gis.umn.edu/download/current/demo5x/ ?
It segfaults.
> If the demo mapfile above seg faults as well then that would indicate a
> problem with the Debian build or some conflict of libs on your box...
> very little we can do about this, you'd have to report the issue to the
> package maintainers. You could consider using prebuilt binaries from FGS
> (http://maptools.org/fgs/) or build completely from source (much more work).
I will report to debian. Thanks for your time.
