[mapserver-users] CGI controls - Symbol
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Jul 14 13:54:31 EDT 2008
Looking at the code I see why referencing another named symbol won't work either. Same reason
as with an image. If you reference the symbol by index then you'll have a shot at making this work
as the code sits now...
Steve
>>> On 7/14/2008 at 11:57 AM, in message <487B858A.8000306 at refractions.net>, Ben
Brehmer <bbrehmer at refractions.net> wrote:
> Thanks Steve,
> Just tried creating a symbol image in my mapfile and referencing that
> through the URL with no luck.
> I've created a ticket for this: http://trac.osgeo.org/mapserver/ticket/2700
> Cheers,
> Ben
> Steve Lime wrote:
>> I wonder if this is related to using an image. If you define another named
> symbol in your
>> mapfile, e.g.:
>> SYMBOL
>> TYPE PIXMAP
>> NAME 'blue_star'
>> IMAGE ./blue_star.gif
>> END
>> and then try to reference it:
>> ...&map.layer[0].CLASS[0].STYLE[0]=SYMBOL+'blue_star'&...
>> Does that work? Might be a reasonable workaround.
>> MapServer resolves symbol names at the end of mapfile parsing and that's
> probably not
>> happening in this case. The reason we wait until the end is because symbols
> and symbolsets
>> can be anywhere in the file. This is probably a bug if you'd please file a
> ticket...
>> Steve
>>>>> On 7/11/2008 at 6:03 PM, in message <4877E6A5.5040903 at refractions.net>, Ben
>>> Dear All,
>>> Just wondering if there are any known problems when trying to modify a
>>> symbol via the URL in Mapserver 5.0.3.
>>> I am trying to do on-the-fly symbol changes with the CGI variables as
>>> follows:
>>> ...&map.layer[0].CLASS[0].STYLE[0]=SYMBOL+'./blue_star.gif'&...
>>> The above produces no errors and a blank image. Seems to me as though
>>> the symbol is simply ignored in the URL because when I assign a color
>>> (map.layer[0].class[0].style[0]=COLOR+151+151+151) I get a whole whack
>>> of points back. Predefining the SYMBOL in the mapfile (SYMBOL
>>> "./blue_star.gif") also works perfectly fine.
>>> Not sure if I'm doing something wrong, but I've tried pretty much every
>>> combination including using using non-image symbols, playing around with
>>> the mapfile, and pulling out my hair. Note that I am also using the DATA
>>> CGI var to supply dynamic data content in the same URL (not sure if this
>>> would make a difference).
>>> Any ideas/suggestions would be greatly appreciated.
>>> Thanks,
>>> Ben Brehmer
>>> The mapfile is pretty straight forward:
>>> DATAPATTERN ".*"
>>> LAYER
>>> NAME "pointlayer"
>>> DATA ""
>>> CONNECTIONTYPE postgis
>>> CONNECTION "host=localhost user=postgres port=5432 dbname=name
>>> password=pass"
>>> CLASSITEM "point_id"
>>> CLASS
>>> NAME ""
>>> STYLE
>>> END
>>> END
>>> Mapserver is compiled with the following options:
>>> MapServer version 5.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT
>>> SUPPORTS=FASTCGI INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>>> INPUT=SHAPEFILE
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
