[mapserver-users] CGI controls - Symbol
Ben Brehmer
bbrehmer at refractions.net
Mon Jul 14 12:57:46 EDT 2008
Thanks Steve,
Just tried creating a symbol image in my mapfile and referencing that
through the URL with no luck.
I've created a ticket for this: http://trac.osgeo.org/mapserver/ticket/2700
Cheers,
Ben
Steve Lime wrote:
> I wonder if this is related to using an image. If you define another named symbol in your
> mapfile, e.g.:
> SYMBOL
> TYPE PIXMAP
> NAME 'blue_star'
> IMAGE ./blue_star.gif
> END
> and then try to reference it:
> ...&map.layer[0].CLASS[0].STYLE[0]=SYMBOL+'blue_star'&...
> Does that work? Might be a reasonable workaround.
> MapServer resolves symbol names at the end of mapfile parsing and that's probably not
> happening in this case. The reason we wait until the end is because symbols and symbolsets
> can be anywhere in the file. This is probably a bug if you'd please file a ticket...
> Steve
>>>> On 7/11/2008 at 6:03 PM, in message <4877E6A5.5040903 at refractions.net>, Ben
> Brehmer <bbrehmer at refractions.net> wrote:
>> Dear All,
>> Just wondering if there are any known problems when trying to modify a
>> symbol via the URL in Mapserver 5.0.3.
>> I am trying to do on-the-fly symbol changes with the CGI variables as
>> follows:
>> ...&map.layer[0].CLASS[0].STYLE[0]=SYMBOL+'./blue_star.gif'&...
>> The above produces no errors and a blank image. Seems to me as though
>> the symbol is simply ignored in the URL because when I assign a color
>> (map.layer[0].class[0].style[0]=COLOR+151+151+151) I get a whole whack
>> of points back. Predefining the SYMBOL in the mapfile (SYMBOL
>> "./blue_star.gif") also works perfectly fine.
>> Not sure if I'm doing something wrong, but I've tried pretty much every
>> combination including using using non-image symbols, playing around with
>> the mapfile, and pulling out my hair. Note that I am also using the DATA
>> CGI var to supply dynamic data content in the same URL (not sure if this
>> would make a difference).
>> Any ideas/suggestions would be greatly appreciated.
>> Thanks,
>> Ben Brehmer
>> The mapfile is pretty straight forward:
>> DATAPATTERN ".*"
>> LAYER
>> NAME "pointlayer"
>> DATA ""
>> CONNECTIONTYPE postgis
>> CONNECTION "host=localhost user=postgres port=5432 dbname=name
>> password=pass"
>> CLASSITEM "point_id"
>> CLASS
>> NAME ""
>> STYLE
>> END
>> END
>> Mapserver is compiled with the following options:
>> MapServer version 5.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT
>> SUPPORTS=FASTCGI INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>> INPUT=SHAPEFILE
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
