[MAPSERVER-USERS] Error: Schema definition in postgis layer
Ritesh Ambastha
group.ritesh at gmail.com
Tue Jul 15 07:07:56 EDT 2008
Hello,
I am connecting to postgis for displaying maps.
I have a schema named as 'testschema' and table 'test'
I get these errors when I try to display the map.
<snip>
1.Without specifying schema:
DATA "the_geom FROM test USING UNIQUE fid SRID -1"
msDrawMap(): Image handling error. Failed to draw layer named 'test'.
prepare_database(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),fid::text from test
WHERE the_geom && setSRID('BOX3D(-548821.411568409 1455242,-506293.588431591
1487129)'::BOX3D, find_srid('','test','the_geom') )' Postgresql reports the
error as 'ERROR: relation "test" does not exist '...............
2. After specifying schema
DATA "the_geom FROM testschema.test USING UNIQUE fid SRID -1"
testschema.test WHERE the_geom && setSRID('BOX3D(-548821.411568409
1455242,-506293.588431591 1487129)'::BOX3D,
find_srid('','testschema.test','the_geom') )' Postgresql reports the error
as 'ERROR: function force_2d(scott.geometry) does not exist LINE 1: ...INARY
CURSOR FOR SELECT asbinary(force_collection(force_2d(t... ^ HINT: No
function matches the given name and argument types. You might need to add
explicit type casts. ' ................
</snip>
Also, when I keep the table in public schema, it works without any error.
I need to know the correct way to define schema in mapfile while using
postgis.
Right now I am using these statements in my mapfile:
CONNECTIONTYPE postgis
CONNECTION "user=postgres password=postgres dbname=map host=xx.xx.xxx.xxx
port=5432"
DATA "the_geom from test USING UNIQUE fid SRID -1"
Thanks,
Ritesh Ambastha
View this message in context: http://www.nabble.com/Error%3A-Schema-definition-in-postgis-layer-tp18462568p18462568.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
