[MAPSERVER-USERS] Connection parameter errors while using
Postgres DB Schema
Venkat Rao Tammineni
vtammineni at roulacglobal.com
Wed Jul 16 05:25:05 EDT 2008
Here is my Example .I think it helps you.
Layer # Layer starts here
Name "GMM 100" #name of the layer
ConnectionType POSTGIS #connection type
Connection "host=192.168.1.158 dbname=GIS password=administrator
user=postgres port=5432" #connection type.
Data "the_geom from rgp_gis_gmm_100_metros" #table name
Thanks and Regards
Venkat.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ritesh
Ambastha
Sent: Wednesday, July 16, 2008 2:44 PM
To: mapserver-users at lists.osgeo.org
Subject: [MAPSERVER-USERS] Connection parameter errors while using Postgres
DB Schema
Hello Readers,
I am facing a problem in defining the DATA path in mapserver while using
PostGIS.
I have two schemas, lets say 'a' and 'b' in a database 'd'
Now, I want to access tables of schema 'a' in the mapserver layer.
I define DATA path like this:
DATA "the_geom FROM a.table_name USING UNIQUE id SRID -1"
Please pour in your thoughts for defining schema in the connection/data
parameters.
Thanks,
Ritesh Ambastha
View this message in context:
http://www.nabble.com/Connection-parameter-errors-while-using-Postgres-DB-Sc
hema-tp18483547p18483547.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
