[MAPSERVER-USERS] Connection parameter errors while using
Postgres DB Schema
Ritesh Ambastha
group.ritesh at gmail.com
Wed Jul 16 05:37:03 EDT 2008
Hey Venkat,
Thanks for the details.
I understand the standard way to write a connection parameter.
I am sure that this table "rgp_gis_gmm_100_metros" is stored in "public"
schema of your database.
My question is, what will you write if you keep this table in some other
schema?
Regards,
Venkatrao wrote:
> Hi,
> Here is my Example .I think it helps you.
> Layer # Layer starts here
> Name "GMM 100" #name of the layer
> ConnectionType POSTGIS #connection type
> Connection "host=192.168.1.158 dbname=GIS password=administrator
> user=postgres port=5432" #connection type.
> Data "the_geom from rgp_gis_gmm_100_metros" #table name
> Thanks and Regards
> Venkat.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ritesh
> Ambastha
> Sent: Wednesday, July 16, 2008 2:44 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [MAPSERVER-USERS] Connection parameter errors while using
> Postgres
> DB Schema
> Hello Readers,
> I am facing a problem in defining the DATA path in mapserver while using
> PostGIS.
> I have two schemas, lets say 'a' and 'b' in a database 'd'
> Now, I want to access tables of schema 'a' in the mapserver layer.
> I define DATA path like this:
> DATA "the_geom FROM a.table_name USING UNIQUE id SRID -1"
> Please pour in your thoughts for defining schema in the connection/data
> parameters.
> Thanks,
> Ritesh Ambastha
> http://www.nabble.com/Connection-parameter-errors-while-using-Postgres-DB-Sc
> hema-tp18483547p18483547.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Connection-parameter-errors-while-using-Postgres-DB-Schema-tp18483547p18483876.html
