[mapserver-users] Changing Point style on-the-fly
George A. Dubin
lysholm at tut.by
Fri Jul 18 06:12:16 EDT 2008
On Thu, 17 Jul 2008 15:47:12 +0300, Paul Spencer <pspencer at dmsolutions.ca>
wrote:
> If you are using MapServer 5.0 or the brand new 5.2 then you can
> probably use attribute binding, which allows you to specify an attribute
> in your data as the source for various parameters in the map file. For
> instance, if you have a field in your database called point_size that
> has a size value then you can do this:
> SIZE [point_size]
> You can also bind to COLOR and most other attributes inside STYLE and
> LABEL. I just went to look for documentation on attribute binding and I
> can't seem to find anything beyond the original rfc
> (http://mapserver.gis.umn.edu/development/rfc/ms-rfc-19) so if you are
> running into trouble, don't hesitate to ask the developers :)
> Cheers
> Paul
> On 17-Jul-08, at 7:52 AM, George A. Dubin wrote:
>> Hi all! I'm firing up a mapserver for our company these days. Mapserver
>> successfully connects to Postgres, and draws points from my database.
>> But I need to change some parameters, such as colour and size of points
>> on-the-fly, depending on the duration of their existence. Is there a
>> way to make Mapserver to pick size and colour of points from Postgres,
>> too?
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
That really works!!! Thanks a lot!
