[mapserver-users] WFS_ENCODING problems
Gabriel Messner
gabmessner at gmail.com
Fri Jul 18 06:28:49 EDT 2008
I´ve solved the problem; I post de solution for future searchings:
1. I keep de Postgis Database encoding to UTF-8
2. I changed the client_encoding in the postgresql.conf to client encoding =
iso-8859-1
3. Then I changed the Layer Metadata in the mapfile to 'Layer_Encoding'
'Latin1'.
Now the special characters 'ñ', 'á', etc are shown properly.
2008/7/9 Guillaume Sueur <guillaume.sueur at neogeo-online.net>:
> it's not.
> default client_encoding is ASCII
> Gabriel Messner a écrit :
>> Thanks, but default client_encoding in PostgreSQL is the database encoding
>> (here, UTF-8)
>> 2008/7/9 Guillaume Sueur <guillaume.sueur at neogeo-online.net <mailto:
>> guillaume.sueur at neogeo-online.net>>:
>> just an idea, but maybe check your client_encoding parameter in
>> postgresql.conf
>> I may be wrong, but I think that mapserver id acting as a client for
>> the db, and may have the results returned into the client_encoding
>> character set.
>> Guillaume
>> Hi all,
>> I´ve set up a WFS server with mapserver. Data is stored in
>> Postgis database. Encoding settings are the followings:
>> -Spatial Data Base encoding is UTF-8
>> -For each layer in the mapfile encofing is also UTF-8 indicated
>> with 'layer_encoding' 'UTF-8'
>> The server retuns successfully geometries and attributes but the
>> the characters 'ñ',á,é,í,ó,ú are missing (spanish).
>> I´ve tried to solve this problem using 'wfs_encofing' 'UTF-8'
>> into the Web object Metadata but when doing so and trying to add
>> a wfs layer with UDig, an alert is displayed saying 'wrong
>> connection parameters'. I´ve also tried with 'ows_endoding' and
>> 'gml_encoding' at Web object Metadata but I fail as well.
>> I´d hughly appreciated if anyone can help me.
>> Thanks in advance.
>> Gabriel Messner
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080718/df964642/attachment.html
