[mapserver-users] Compiling Issues: Ubuntu 8.04 -- libgd and
gdFontCacheSetup
Matthew Pettis
matthew.pettis at gmail.com
Sat Jul 19 12:54:59 EDT 2008
I actually downloaded, unpacked, configure/make/make install'ed from
http://www.libgd.org/releases/gd-2.0.35.tar.gz
I assume that would be the same thing as your command below?
thanks,
Matt
On Sat, Jul 19, 2008 at 12:28 AM, thomas bonfort
<thomas.bonfort at gmail.com> wrote:
> hi,
> have you installed the libgd development packages ?
> # apt-get install libgd-dev
> thomas
> On Sat, Jul 19, 2008 at 1:26 AM, Matthew Pettis
> <matthew.pettis at gmail.com> wrote:
>> Hi All,
>> This still fails... below is my configuration parameter setup and the
>> output of configure are below... any suggestions?
>> thanks,
>> matt
>> === configure parameters ===
>> ./configure --with-ogr=/usr \
>> --with-gdal=/usr \
>> --with-httpd=/usr/sbin/apache2 \
>> --with-wfsclient \
>> --with-wmsclient \
>> --enable-debug \
>> --with-curl=/usr \
>> --with-proj=/usr \
>> --with-threads \
>> --with-tiff \
>> --with-libiconv=/usr/local/lib \
>> --with-jpeg \
>> --with-freetype=/usr/lib/xorg/modules/fonts/ \
>> --with-threads \
>> --with-wcs \
>> --with-xml2-config=/usr/bin/xml2-config \
>> --with-gd=/usr \
>> --with-php=/usr
>> === output of configure script ===
>> checking for gcc... gcc
>> checking for C compiler default output file name... a.out
>> checking whether the C compiler works... yes
>> checking whether we are cross compiling... no
>> checking for suffix of executables...
>> checking for suffix of object files... o
>> checking whether we are using the GNU C compiler... yes
>> checking whether gcc accepts -g... yes
>> checking for gcc option to accept ANSI C... none needed
>> checking for g++... g++
>> checking whether we are using the GNU C++ compiler... yes
>> checking whether g++ accepts -g... yes
>> checking for ranlib... ranlib
>> checking for flex... no
>> checking for lex... no
>> checking for yywrap in -lfl... no
>> checking for yywrap in -ll... no
>> checking for bison... no
>> checking for byacc... no
>> checking if compiler supports -R... no
>> checking if compiler supports -Wl,-rpath,... yes
>> checking for exp in -lm... yes
>> checking for __gxx_personality_v0 in -lstdc++... yes
>> checking how to run the C preprocessor... gcc -E
>> checking for egrep... grep -E
>> checking for ANSI C header files... yes
>> checking for strcasecmp... yes
>> checking for strncasecmp... yes
>> checking for strdup... yes
>> checking for strlcat... no
>> checking for vsnprintf... yes
>> MapServer Version from mapserver.h: '5.0.3'
>> configure: checking where FreeType 2.x is installed...
>> using libfreetype from -L/usr/lib/xorg/modules/fonts/ -lfreetype
>> configure: checking where Zlib is installed...
>> checking for zlibVersion in -lz... yes
>> using libz from system libs (-DUSE_ZLIB).
>> configure: checking where PNG is installed...
>> checking for png_init_io in -lpng... yes
>> using libpng from system libs.
>> configure: checking whether we should include JPEG support...
>> checking for jpeg_read_header in -ljpeg... yes
>> using libjpeg from system libs.
>> configure: checking where libXpm is installed...
>> checking for XpmFreeXpmImage in -lXpm... yes
>> using libXpm from system libs.
>> configure: checking where libiconv is installed...
>> checking for iconv_open in -lc... yes
>> checking for libiconv_open in -liconv... yes
>> using libiconv from -L -liconv
>> libiconv found. Enabling internationalization (-DUSE_ICONV)
>> configure: checking for GD 2.0.16 or higher...
>> checking for gdFontCacheSetup in -lgd... no
>> configure: checking whether GD needs libiconv...
>> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr.
>> Make sure GD 2.0.16 or higher is compiled before calling configure.
>> You may also get this error if you didn't specify the appropriate
>> location for one of GD's dependencies (freetype, libpng, libjpeg or
>> libiconv).
>> On Fri, Jul 18, 2008 at 9:04 AM, Matthew Pettis
>>> Replied to your previous one -- I will try again tonight with your
>>> suggestion and update the list with the results -- Thanks again!
>>> Matt
>>> On Fri, Jul 18, 2008 at 8:54 AM, Daniel Morissette
>>> <dmorissette at mapgears.com> wrote:
>>>> As I wrote in a previous message, is it possible that you configured using
>>>> "--with-gd=/usr/lib"? You should use "--with-gd=/usr" only and the configure
>>>> script should take care of looking in the right subdirectory for each file.
>>>> Daniel
>>>> Matthew Pettis wrote:
>>>>> Hi,
>>>>> More and different compiling issues from the one I've already
>>>>> posted... My configure script errors as shown below (truncated because
>>>>> I believe the most important part is included):
>>>>> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/lib.
>>>>> libiconv).
>>>>> Now, I have libgd version 2.0.35, so this should work... I have gd.h
>>>>> and libgd.a/libgd.so (the latter are in /usr/lib/). I think it is
>>>>> choking because of the gdFontCacheSetup. Any idea on how to fix this?
>>>>> Thanks,
>>>>> Matt
>>>> Daniel Morissette
>>>> http://www.mapgears.com/
>>> It is from the wellspring of our despair and the places that we are
>>> broken that we come to repair the world.
>>> -- Murray Waas
>> -- Murray Waas
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
-- Murray Waas
