[mapserver-users] Compiling Issues: Ubuntu 8.04 -- libgd and
gdFontCacheSetup
Matthew Pettis
matthew.pettis at gmail.com
Sat Jul 19 21:17:57 EDT 2008
Guillaume,
Correct, the output was the same modulo the directory that gd.h and
the others were not found in...
And I did try your suggested change to ld.so.conf (I wasn't sure how
it should be added, so I tried two ways:
/usr/lib
and
include /usr/lib
then running /sbin/ldconfig)
both with similar results.
Thanks,
Matt
On Sat, Jul 19, 2008 at 4:45 PM, Guillaume Sueur
<guillaume.sueur at neogeo-online.net> wrote:
> configure dump can't be the same. It should say :
> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/local
> instead of
> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr.
> if it is so, did you check your /etc/ld.so.conf as asked previously and run
> ldconfig afterwards ?
> Regards,
> Guillaume
> Matthew Pettis a écrit :
>> Hi Guillaume, All,
>> Guillaume was right, the install is in /usr/local, but when I changed
>> the configure script to take
>> --with-gd=/usr/local
>> I get the same results as before (./configure dump is same as
>> previously posted). Other ideas?
>> Thanks,
>> Matt
>> On Sat, Jul 19, 2008 at 12:30 PM, Guillaume Sueur
>>> yes, it would. be you probably didn't install it in /usr like you specify
>>> in
>>> your configure.
>>> so try with --with-gd=/usr/local instead
>>> good luck !
>>> Guillaume
>>>> Hi,
>>>> I actually downloaded, unpacked, configure/make/make install'ed from
>>>> http://www.libgd.org/releases/gd-2.0.35.tar.gz
>>>> I assume that would be the same thing as your command below?
>>>> thanks,
>>>> Matt
>>>> On Sat, Jul 19, 2008 at 12:28 AM, thomas bonfort
>>>> <thomas.bonfort at gmail.com> wrote:
>>>>> hi,
>>>>> have you installed the libgd development packages ?
>>>>> # apt-get install libgd-dev
>>>>> thomas
>>>>> On Sat, Jul 19, 2008 at 1:26 AM, Matthew Pettis
>>>>> <matthew.pettis at gmail.com> wrote:
>>>>>> Hi All,
>>>>>> This still fails... below is my configuration parameter setup and the
>>>>>> output of configure are below... any suggestions?
>>>>>> thanks,
>>>>>> matt
>>>>>> === configure parameters ===
>>>>>> ./configure --with-ogr=/usr \
>>>>>> --with-gdal=/usr \
>>>>>> --with-httpd=/usr/sbin/apache2 \
>>>>>> --with-wfsclient \
>>>>>> --with-wmsclient \
>>>>>> --enable-debug \
>>>>>> --with-curl=/usr \
>>>>>> --with-proj=/usr \
>>>>>> --with-threads \
>>>>>> --with-tiff \
>>>>>> --with-libiconv=/usr/local/lib \
>>>>>> --with-jpeg \
>>>>>> --with-freetype=/usr/lib/xorg/modules/fonts/ \
>>>>>> --with-threads \
>>>>>> --with-wcs \
>>>>>> --with-xml2-config=/usr/bin/xml2-config \
>>>>>> --with-gd=/usr \
>>>>>> --with-php=/usr
>>>>>> === output of configure script ===
>>>>>> checking for gcc... gcc
>>>>>> checking for C compiler default output file name... a.out
>>>>>> checking whether the C compiler works... yes
>>>>>> checking whether we are cross compiling... no
>>>>>> checking for suffix of executables...
>>>>>> checking for suffix of object files... o
>>>>>> checking whether we are using the GNU C compiler... yes
>>>>>> checking whether gcc accepts -g... yes
>>>>>> checking for gcc option to accept ANSI C... none needed
>>>>>> checking for g++... g++
>>>>>> checking whether we are using the GNU C++ compiler... yes
>>>>>> checking whether g++ accepts -g... yes
>>>>>> checking for ranlib... ranlib
>>>>>> checking for flex... no
>>>>>> checking for lex... no
>>>>>> checking for yywrap in -lfl... no
>>>>>> checking for yywrap in -ll... no
>>>>>> checking for bison... no
>>>>>> checking for byacc... no
>>>>>> checking if compiler supports -R... no
>>>>>> checking if compiler supports -Wl,-rpath,... yes
>>>>>> checking for exp in -lm... yes
>>>>>> checking for __gxx_personality_v0 in -lstdc++... yes
>>>>>> checking how to run the C preprocessor... gcc -E
>>>>>> checking for egrep... grep -E
>>>>>> checking for ANSI C header files... yes
>>>>>> checking for strcasecmp... yes
>>>>>> checking for strncasecmp... yes
>>>>>> checking for strdup... yes
>>>>>> checking for strlcat... no
>>>>>> checking for vsnprintf... yes
>>>>>> MapServer Version from mapserver.h: '5.0.3'
>>>>>> configure: checking where FreeType 2.x is installed...
>>>>>> using libfreetype from -L/usr/lib/xorg/modules/fonts/ -lfreetype
>>>>>> configure: checking where Zlib is installed...
>>>>>> checking for zlibVersion in -lz... yes
>>>>>> using libz from system libs (-DUSE_ZLIB).
>>>>>> configure: checking where PNG is installed...
>>>>>> checking for png_init_io in -lpng... yes
>>>>>> using libpng from system libs.
>>>>>> configure: checking whether we should include JPEG support...
>>>>>> checking for jpeg_read_header in -ljpeg... yes
>>>>>> using libjpeg from system libs.
>>>>>> configure: checking where libXpm is installed...
>>>>>> checking for XpmFreeXpmImage in -lXpm... yes
>>>>>> using libXpm from system libs.
>>>>>> configure: checking where libiconv is installed...
>>>>>> checking for iconv_open in -lc... yes
>>>>>> checking for libiconv_open in -liconv... yes
>>>>>> using libiconv from -L -liconv
>>>>>> libiconv found. Enabling internationalization (-DUSE_ICONV)
>>>>>> configure: checking for GD 2.0.16 or higher...
>>>>>> checking for gdFontCacheSetup in -lgd... no
>>>>>> configure: checking whether GD needs libiconv...
>>>>>> Make sure GD 2.0.16 or higher is compiled before calling configure.
>>>>>> You may also get this error if you didn't specify the appropriate
>>>>>> location for one of GD's dependencies (freetype, libpng, libjpeg or
>>>>>> libiconv).
>>>>>> On Fri, Jul 18, 2008 at 9:04 AM, Matthew Pettis
>>>>>>> Replied to your previous one -- I will try again tonight with your
>>>>>>> suggestion and update the list with the results -- Thanks again!
>>>>>>> Matt
>>>>>>> On Fri, Jul 18, 2008 at 8:54 AM, Daniel Morissette
>>>>>>> <dmorissette at mapgears.com> wrote:
>>>>>>>> As I wrote in a previous message, is it possible that you configured
>>>>>>>> using
>>>>>>>> "--with-gd=/usr/lib"? You should use "--with-gd=/usr" only and the
>>>>>>>> configure
>>>>>>>> script should take care of looking in the right subdirectory for
>>>>>>>> each
>>>>>>>> file.
>>>>>>>> Daniel
>>>>>>>> Matthew Pettis wrote:
>>>>>>>>> Hi,
>>>>>>>>> More and different compiling issues from the one I've already
>>>>>>>>> posted... My configure script errors as shown below (truncated
>>>>>>>>> because
>>>>>>>>> I believe the most important part is included):
>>>>>>>>> /usr/lib.
>>>>>>>>> configure.
>>>>>>>>> libiconv).
>>>>>>>>> Now, I have libgd version 2.0.35, so this should work... I have
>>>>>>>>> gd.h
>>>>>>>>> and libgd.a/libgd.so (the latter are in /usr/lib/). I think it is
>>>>>>>>> choking because of the gdFontCacheSetup. Any idea on how to fix
>>>>>>>>> this?
>>>>>>>>> Thanks,
>>>>>>>>> Matt
>>>>>>>> Daniel Morissette
>>>>>>>> http://www.mapgears.com/
>>>>>>> It is from the wellspring of our despair and the places that we are
>>>>>>> broken that we come to repair the world.
>>>>>>> -- Murray Waas
>>>>>> -- Murray Waas
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Guillaume SUEUR
> Expert SIG et OpenSource
> NEOGEO
> 46 RUE MATABIAU
> 31000 TOULOUSE
> 06 74 91 95 20
> Site web : http://www.neogeo-online.net
-- Murray Waas
