[mapserver-users] More info on DNC problem
Fawcett, David
David.Fawcett at state.mn.us
Tue Jul 22 11:45:03 EDT 2008
Derek,
It sounds like MapServer can't find your proj4 library. You can add a
line to the map file to tell MapServer where to look for proj. Take a
look at: http://mapserver.gis.umn.edu/docs/reference/mapfile/mapObj
If your first test is to just see if you can read the data, strip all of
the projection blocks out of your map file. If you aren't trying to
re-project or serve the data us as a WMS, you don't need to specify the
projection. Just make sure that your extent is expressed in the units
of the underlying projection. (decimal degrees)
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Derek Bain
Sent: Tuesday, July 22, 2008 10:35 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] More info on DNC problem
Hi
I used the command
ogrinfo -ro -summary
gltp:/vrf/c:/ms4w/apps/some_folder/data/DNC13/H1316030
on a folder containing digital nautical charts to get the
listing below. I then created the map file using the info for layer 14 (
hydarea at hyd(*)_area (Polygon) ) and using the extents from orginfo with
hydarea at hyd(*)_area as its parameter. I tried testing the map file using
shp2img but keep getting the error "Projection library error. No such
file or directory" From what I can find from web searching etc, this
error description covers a lot of different errors.
From what i can see from hydarea at hyd, hyd is a subfolder of
H1316030 i.e C:\ms4w\apps\some_folder\data\DNC13\H1316030\HYD and
hydarea is file inside that folder with the extension .AFT
Can anyone offer any help
Thanks
Derek
Map File---->
# Digital Nautical Maps for H1316030
# (14: hydarea at hyd(*)_area (Polygon))
LAYER
NAME "hydarea_hyd_area"
TYPE POLYGON
CONNECTIONTYPE OGR
# MapServer Layer = ogrinfo layer - 1 i.e. 14-1 = 13
CONNECTION
"C:/ms4w/Apps/some_folder/data/DNC13/H1316030,13" # 14:
STATUS ON
PROJECTION
"init=epsg:4326"
END # End Projection
METADATA
"wms_title" "hydarea at hyd(*)_area"
"wms_abstract" "hydarea at hyd(*)_area
abstract goes here ....."
"wms_srs" "epsg:4326"
"wms_name" "hydarea"
# [minx_left] [miny_bottom]
[maxx_right] [maxy_top]
"wms_extent" "-118.646797 32.933327
-118.475853 33.066673"
"wms_onlineresource"
"http://localhost:8082/cgi-bin/mapserv.exe?map=C:/ms4w/apps/some_folder/
dnc2.map"
END # End Metadata
CLASS
NAME "hydarea"
COLOR 255 0 0
END # End Class
END # End Layer
ORGINFO output----------->
Layer name: hydarea at hyd(*)_area
Geometry: Polygon
Feature Count: 63
Extent: (-118.646797, 32.933327) - (-118.475853, 33.066673)
Layer SRS WKT:
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4269"]]
f_code: String (5.0)
acc: Integer (5.0)
cvh: Real (15..6)
cvl: Real (15.6)
tile_id: Integer (5.0)
fac_id: Integer (10.0)
1: buildnga at cul(*)_area (Polygon)
2: transl at cul(*)_line (Line String)
3: buildngp at cul(*)_point (Point)
4: commp at cul(*)_point (Point)
5: industp at cul(*)_point (Point)
6: ecrarea at ecr(*)_area (Polygon)
7: foreshoa at ecr(*)_area (Polygon)
8: coastl at ecr(*)_line (Line String)
9: foreshol at ecr(*)_line (Line String)
10: islandp at ecr(*)_point (Point)
11: ecrtext at ecr(*)_text (Point)
12: envarea at env(*)_area (Polygon)
13: tidep at env(*)_point (Point)
15: hydline at hyd(*)_line (Line String)
16: botcharp at hyd(*)_point (Point)
17: soundp at hyd(*)_point (Point)
18: embanka at lcr(*)_area (Polygon)
19: lcrline at lcr(*)_line (Line String)
20: limbndya at lim(*)_area (Polygon)
21: limbndya at lim(*)_area (Polygon)
22: distl at lim(*)_line (Line String)
23: distl at lim(*)_line (Line String)
24: limbndyl at lim(*)_line (Line String)
25: limbndyl at lim(*)_line (Line String)
26: routel at lim(*)_line (Line String)
27: routel at lim(*)_line (Line String)
28: limbndyp at lim(*)_point (Point)
29: leadingl at nav(*)_line (Line String)
30: buoybcnp at nav(*)_point (Point)
31: lightsp at nav(*)_point (Point)
32: dangera at obs(*)_area (Polygon)
33: hazarda at obs(*)_area (Polygon)
34: obstruca at obs(*)_area (Polygon)
35: reefa at obs(*)_area (Polygon)
36: hazardl at obs(*)_line (Line String)
37: dangerp at obs(*)_point (Point)
38: hazardp at obs(*)_point (Point)
39: obstrucp at obs(*)_point (Point)
40: ruinsp at obs(*)_point (Point)
41: piera at por(*)_area (Polygon)
42: structra at por(*)_area (Polygon)
43: pierl at por(*)_line (Line String)
44: structrl at por(*)_line (Line String)
45: relline at rel(*)_line (Line String)
46: relpoint at rel(*)_point (Point)
47: dqyarea at dqy(*)_area (Polygon)
48: tileref at tileref(*)_area (Polygon)
49: libref at libref(*)_line (Line String)
Not happy with your email address?
Get the one you really want
<http://uk.docs.yahoo.com/ymail/new.html> - millions of new email
addresses available now at Yahoo!
<http://uk.docs..yahoo.com/ymail/new.html>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080722/796619c0/attachment.html
