[mapserver-users] v5.0.0 - CLASSITEM has double quote in
fieldvalue
Mike Saunt
mikesaunt at gmail.com
Tue Jul 22 06:48:45 EDT 2008
Hi Steve / Daniel
I'll try to pull something together later today...
Kind regards
mike
On 21/07/2008, Daniel Morissette <dmorissette at mapgears.com> wrote:
> Steve is right, I had only guessed that there might be a bug based on the
> problem description, but we've been unable to reproduce the issue that you
> report. I meant to reply on Friday asking for a testcase to reproduce but I
> forgot.
> Daniel
> Steve Lime wrote:
>> While I'm glad it works (the regex should execute faster too) the other
>> expression should
>> have worked as well. Can you share the data you were using for some
>> testing?
>> Steve
>> On 7/18/2008 at 8:16 AM, in message
>>>> <5a9686e80807180616n492ec21cma0170d2dfc9633b9 at mail.gmail.com>, "Mike
>> Saunt"
>> <mikesaunt at gmail.com> wrote:
>>> Alexandre
>>> Excellent - that works!
>>> FYI - This is why I believe that Open Source can easily prevail even
>> when
>>> people put down the 'many eyes see more bugs' notion. In another
>> life I
>>> worked with / as a partner for a proprietary company (now you can
>> buy
>>> franking machines from the same parent company wink wink nudge nudge)
>> and
>>> you'd never get this response so quickly and also having 'had it from
>> the
>>> horses mouth a.k.a. Developers' that there is an issue and this is
>> the best
>>> way around it.
>>> Thanks so much Alexandre
>>> Kind regards
>>> Mike
>>> 2008/7/18 Alexandre Dube <adube at mapgears.com>:
>>> I've been told by developers that there seems to be a bug when using
>>> " " in
>>> the expression parser...
>>>> You should use a regular expression instead like the following :
>>>> EXPRESSION /^Lane Closure$|^Multi-Way Signals$|^Road
>>> Closure$|^Stop\/Go
>>> Boards$|^Two-Way Signals$/
>>>> See at : http://mapserver.gis.umn.edu/docs/howto/msexpressions
>>>> Mike Saunt wrote:
>>>> thanks Alexandre but unfortunately it didn't work
>>>>> Do you know if there is a way of forcing MapServer to read out the
>>>> literal
>>> string i.e. sort of like escaping it? in .NET you can say
>>>> @stringvariable
>>> and it will ignore quotes inside etc?
>>>>> Cheers
>>>>> Mike
>>>> <mailto:adube at mapgears.com
>>>>> Hi Mike,
>>>>> I'm not sure about that, but try eq instead of =
>>>>> EXPRESSION ('[TRAFFIC_TYPE]' eq 'Lane Closure' OR ...
>>>>> Best Regards,
>>>>> Alexandre
>>>>> Mike Saunt wrote:
>>>>> Hi All
>>>>> I've got a MapFile that used to work fine in v4.10 but now
>>>>> fails in v5.0
>>>>> Basically the CLASSITEM field has double quote in field
>>>> value
>>> and this is then returning an error - msEvalExpression:
>>>>> Expression parser error. Failed to parse expression
>>>>> The CLASS EXPRESSION looks like this
>>>>> CLASSITEM 'TRAFFIC_TYPE' CLASS
>>>>> EXPRESSION ('[TRAFFIC_TYPE]' = 'Lane Closure' OR
>>>>> '[TRAFFIC_TYPE]' = 'Multi-Way Signals' OR '[TRAFFIC_TYPE]'
>>> 'Road Closure' OR '[TRAFFIC_TYPE]' = 'Stop/Go Boards' OR
>>>>> '[TRAFFIC_TYPE]' = 'Two-Way Signals')
>>>>> STYLE # Severe (RED)
>>>>> SYMBOL 'triangle'
>>>>> SIZE 9
>>>>> COLOR 255 0 0
>>>>> OUTLINECOLOR 0 0 0
>>>>> END
>>>>> END
>>>>> I've tried double quote vs. single quotes in the map file
>>>> but
>>> to no avail
>>>>> Anyone any thoughts?
>>>>> Kind regards
>>>>> Mike
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org <mailto:
>>>>> mapserver-users at lists.osgeo.org>
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>> -- Alexandre Dubé
>>>>> Mapgears
>>>>> www.mapgears.com <http://www.mapgears.com>
>>>> Alexandre Dubé
>>>> Mapgears
>>>> www.mapgears.com
> Daniel Morissette
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080722/dedfa959/attachment-0001.html
