[MAPSERVER-USERS] Display of polygon in map
S.Reena
reena at indiamail.com
Tue Jul 29 02:38:24 EDT 2008
LAYER
NAME gps_polygon
STATUS on
TYPE polygon
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost dbname=gps_data user=postgres
password=postgres port=5432"
DATA "newgeom FROM gps_polygon USING UNIQUE gid"
LABELCACHE on
#LABELITEM 'name'
HEADER 'templates/header.html'
FOOTER 'templates/footer.html'
TOLERANCE 3
STYLE
#COLOR 212 192 100
# OUTLINECOLOR 200 100 200
OUTLINECOLOR 0 0 255
END
LABEL
COLOR 255 0 0
POSITION ul
SIZE large
END # label
END # class
END # layer
pag66 wrote:
> Hi friend post the connection that you're using maybe it a problem with
> the select statement, try "the_geom from table using unique gid" if you
> have and gid field
View this message in context: http://www.nabble.com/Display-of-polygon-in-map-tp18674352p18706320.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
