[mapserver-users] Re: mapscript querybypoint on tiled
rasterlayers?
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Jul 30 12:37:41 EDT 2008
Thanks for the bug report. It may be that we missed a spot with the changes for relative
path support. The raster query stuff is off by itself so it's certainly possible.
Steve
>>> On 7/29/2008 at 8:23 PM, in message <488FC2A9.8030205 at alumni.uwaterloo.ca>,
Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
> Steve,
> Thanks for the reply. To clarify, I am using 5.2. I'm guessing by what
> you're saying is that bugs with a new feature like this are to be
> expected - I just wanted to check if it was already known to anyone else
> before submitting a ticket in the trac.
> Regards,
> Mike
> Steve Lime wrote:
>> Support for tile names relative to the tile index is brand new in 5.2 so in
> older versions
>> absolute paths or paths relative to the mapfile were your only options.
>> Steve
>>>>> On 7/29/2008 at 12:44 PM, in message <488F56FC.9070701 at alumni.uwaterloo.ca>,
>>> Ok...I figured out the problem pretty much right after I clicked send on
>>> that last message. I had generated my tile index.shp with relative
>>> paths for the LOCATION field (i.e., relative to the shp file). I just
>>> regenerated it with absolute path names, and it the query function works
>>> fine.
>>> So would this be a known bug of any sort, or is it just bad practice to
>>> use relative filenames with MapServer?
>>> Regards,
>>> Mike
>>> Mike Leahy wrote:
>>>> Hello list,
>>>> I'm sure this one has come up before, but I can't seem to figure out
>>>> what I need to do. I have some tiled raster layers that I've got in a
>>>> mapfile that is being used for generating ka-map tiles. I'm trying to
>>>> query the values on these layer using the queryByPoint function in
>>>> php_mapscript. I have a generic identify function that returns results
>>>> for any of my vector layers, and for non-tiled raster layers - just not
>>>> for the tiled raster layers. Is it possible to query tiled raster
>>>> layers? If so, can someone spot what I'm doing wrong below?
>>>> The tiled-raster layers in the mapfile generally look like this:
>>>> LAYER
>>>> NAME "Tiled Raster"
>>>> GROUP "Tiled Raster"
>>>> STATUS ON
>>>> TYPE RASTER
>>>> TILEINDEX "/data/index.shp"
>>>> TILEITEM "LOCATION"
>>>> METADATA
>>>> "imageformat" "AGG_JPEG"
>>>> END
>>>> PROJECTION
>>>> "init=epsg:4326"
>>>> END
>>>> END
>>>> And here is the function in PHP:
>>>> public function Identify($oMap,$layer,$x,$y,$cellSize)
>>>> $oLayer = $oMap->getLayerByName($layer);
>>>> if (in_array($oLayer->type,
>>>> array(MS_LAYER_POINT,MS_LAYER_LINE,MS_LAYER_POLYGON)))
>>>> $oLayer->set("toleranceunits",$oMap->units);
>>>> $oLayer->set("tolerance",$cellSize*3);
>>>> else
>>>> $oLayer->set("tolerance",0);
>>>> $oLayer->set("template","dummy.html");
>>>> $oQPoint = ms_newPointObj();
>>>> $oQPoint->setXY($x,$y);
>>>> $aResults = array();
>>>> if (@$oLayer->queryByPoint($oQPoint,MS_MULTIPLE,$oLayer->tolerance) ==
>>>> MS_SUCCESS)
>>>> $oLayer->open();
>>>> $nResults = $oLayer->getNumResults();
>>>> for ($i=0;$i<$nResults;$i++)
>>>> $oResult = $oLayer->getResult($i);
>>>> $oShape = $oLayer->getShape($oResult->tileindex,
>>>> $oResult->shapeindex);
>>>> $aResults[] = array($oResult,$oShape);
>>>> return $aResults;
>>>> Thanks in advance for any help,
>>>> Mike
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
