[mapserver-users] compare date in class
Ben Madin
ben at remoteinformation.com.au
Fri Jun 6 21:02:04 EDT 2008
G'day Vinc,
It might be easier to code the expression check into the SQL
statement. I could be wrong, but I suspect that this would make the
execution of the statements much faster as well, as increasingly
complex expression checking I think is relatively slow in MapServer,
but shouldn't stress a database. (If I am wrong, it would be good to
know!!)
Off the top of my head, something like this might work:
> DATA 'the_geom from (select the_geom, id, oid, ...., start_date
> from table) as foo'
Would become :
DATA 'the_geom from (select the_geom, id, oid, ...., start_date,
CASE WHEN start_date < now()
THEN 'old'
WHEN start_date > now()
THEN 'future'
ELSE 'now'
END AS status
from table) as foo'
then make :
CLASSITEM status
and CLASS EXPRESSION 'now'
Good luck!
cheers
Ben
On 07/06/2008, at 12:00 AM, mapserver-users-request at lists.osgeo.org
wrote:
> From: patruno at istat.it
> Date: 6 June 2008 9:05:45 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] compare date in class
> Hi list!
> I'd like to ask you if there is a way to compare a field date (mm-gg-
> yyyy) coming from a PostGIS query with the current date. (and above
> all how to get the current date ....)
> My goal is to use a point layer with different colours depending on
> expression result in the 'class' block.
> Ex:
> CONNECTION 'dbname=xxxx user=username password=password
> host=localhost'
> from table) as foo'
> CLASS
> EXPRESSION (current_date > start_date)
> NAME "red"
> TEXT ([id])
> STYLE
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> END
> Thanks in advance
> Vinc
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
Out here, it pays to know...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080607/cc4ddfb1/attachment.html
