[mapserver-users] GetFeatureInfo from Oracle Spatial
Kristian Thy
thy at 42.dk
Sat Jun 7 18:49:19 EDT 2008
Hi list
I've made a small openlayers viewer that shows a data layer from a
materialized view in Oracle Spatial. When clicking on the map, I do a
simple GetFeatureInfo which works when I test it with a shapefile-based
layer, but when I move to the Oracle layer, I get an error message
saying that no features were found with MAXIMO_ID = 0 (something to that
effect, anyways). Unfortunately this is an internal GIS app, so I can't
demo it.
The relevant layer definition in my map file:
LAYER
NAME 'TRIM-Q'
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION "******@******"
DATA "SHAPE FROM (SELECT MAXIMO_ID, ASSETTYPE, SHAPE FROM MAPSERVER_TRIMQ) USING UNIQUE MAXIMO_ID SRID 32632 VERSION 10g"
TEMPLATE "trim.html"
HEADER "trim_header.html"
FOOTER "trim_footer.html"
TOLERANCE 20
DUMP true
METADATA
"wms_title" "TRIM-Q"
"wms_srs" "EPSG:32632"
"wms_include_items" "ALL"
"ows_include_items" "ALL"
"gml_include_items" "ALL"
END #metadata
CLASS
NAME 'vejskab'
EXPRESSION ('[ASSETTYPE]' = 'VEJSKAB')
STYLE
SYMBOL 'square'
OFFSET -4 -2
END #STYLE
LABEL
type truetype
antialias true
font arial_black
size 8
position ll
color 0 0 0
outlinecolor 255 255 255
buffer 2
partials false
END #label
TEXT ([MAXIMO_ID])
END #class
CLASS
#NAME faerdselstavle
EXPRESSION ('[ASSETTYPE]' = 'TAVLE')
STYLE
SYMBOL 'triangle'
OFFSET -10 2
END #STYLE
LABEL
FORCE true
type truetype
antialias true
font arial_black
size 8
position lc
color 0 0 0
buffer 0
partials false
end #label
TEXT ([MAXIMO_ID])
END #class
CLASS
#NAME 'other values'
STYLE
SYMBOL 'circle'
SIZE 2
COLOR 100 0 0
END #STYLE
LABEL
type truetype
antialias true
font arial_black
size 8
position uc
color 0 0 0
buffer 2
partials false
end #label
TEXT ([MAXIMO_ID])
END #class
SIZEUNITS PIXELS
STATUS ON
UNITS meters
MAXSCALE 60000
LABELMAXSCALE 60000
END #layer
The OpenLayers code I use for calling GetFeatureInfo:
map.events.register('click', map, function (e)
var url = trimq.getFullRequestString({
REQUEST: 'GetFeatureInfo',
EXCEPTIONS: 'application/vnd.ogc.se_xml',
BBOX: trimq.map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/plain',
QUERY_LAYERS: 'TRIM-Q',
RADIUS: 5,
WIDTH: trimq.map.size.w,
HEIGHT: trimq.map.size.h});
document.getElementById('map').style.cursor = 'wait';
OpenLayers.loadURL(url, '', this, handleResponse);
Event.stop(e);
function handleResponse(response)
document.getElementById('map').style.cursor = 'auto';
alert(response.responseText);
As mentioned, this works if I query a shapefile-based layer, so I assume
the javascript is ok. Any ideas what my problem is?
\\kristian
... et nemo ex vobis interrogat me: »Quo vadis?«
