[mapserver-users] CGI Class Expression V5.0.2 cannot change
David Martin
David at itbeyond.com.au
Tue Mar 4 21:49:38 EST 2008
Hi I am trying to change the value of a class expression using the cgi
command line in v5.0.2 and I cannot effect the change.
Layer Defn:
LAYER
NAME "EOMapID"
TYPE POLYGON
STATUS OFF
DATA "..\ExplorOz\EO_Maps"
CLASSITEM "ID"
CLASS
NAME "Area covered by map"
STYLE
SYMBOL 21
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 156 156 156
END
TEMPLATE "..\Templates/EO_Treks.html"
END
HEADER "..\Templates\EO_Treks_header.html"
FOOTER "..\Templates\EO_Treks_footer.html"
TOLERANCE 2
END
Using the following command all do not work:
&map.layer[EOMapID].class[0]=expression+'935'
&map.layer[EOMapID].class=expression+'935'
&map.layer[EOMapID].class[0].style[0]=expression+'935'
&map.layer[EOMapID]=class+expression+'935'
Most of these return the following error:
loadClass(): Unknown identifier. Parsing error near (expression):(line
1)
I even added EXPRESSION /./ in the map file to ensure the line existed
and still the same errors. I then just to be sure added EXPRESSION '935'
and it worked perfectly.
Can someone point me in the right direction - this should be simple.....
Regards
David Martin
Managing Director
I.T. Beyond Pty Ltd
Postal:
PO BOX 967
HILLARYS WA 6923
Ph:
(08) 9403 3737
Mobile:
0417 677 275
Fax:
(08) 9403 3738
Skype:
itbeyond_david
Check out our websites: www.ExplorOz.com <http://www.exploroz.com/> and
www.itbeyond.com.au <http://www.itbeyond.com.au/>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080305/76243f71/attachment-0001.html
