[mapserver-users] Postgis schema and query by point
Luca Casagrande
luca.casagrande at gmail.com
Fri Mar 7 03:40:29 EST 2008
Hello everybody,
I am experiencing some troubles running a query by point using mapscript:
the problem is that if the table is in "public" schema, the query goes fine,
instead, using another schema, got an error.
The only change i made in the mapfile is to add schema in the DATA line.
Looking at the table, I noticed that there's not a gid or oid column, but
then I don't understand why it works in public and not in other ones.
Thank you very much
Luca
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080307/ad594f6e/attachment-0001.html
