[mapserver-users] MapServer 4.8.3: MapScript setProjection
Rob
gis at vanbooth.com
Tue Mar 11 07:10:11 EDT 2008
Hi
I'm supporting an instance of MapServer 4.8.3 and I am trying to improve the
performance of the map drawing.
I've a java app that modifies the JNI setProjection object, using
'init=epsg:27700' as its argument.
This seems to take approx 200ms for every layer that I add to my request
(rendered or not), which can drastically increase the time taken to draw a
map (my standard request includes 18 layers).
I read http://mapserver.gis.umn.edu/docs/howto/mapfiletuning about using
inline projection parameters and how it is much quicker than using an epsg
lookup, but I'm having problems.
Using http://spatialreference.org/ref/epsg/27700/ I determined that the
projection parameter should now be
'+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-100000
+ellps=airy +datum=OSB36 +units=m +no_defs'
but this just gives me an error in setProjection - unknown eliptical
parameter name.
The advice here (
http://comments.gmane.org/gmane.comp.gis.mapserver.user/18519) suggests that
I should be using the proj4 format - is that correct?
Does anybody have any idea how I can modify my projection parameter so that
it works? FWIW, upgrading MapServer is probably out of the question.
MTIA
Rob
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080311/f0eb7b36/attachment.html
