[mapserver-users] WFS - DescribeFeatureType
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Wed Mar 12 05:34:56 EDT 2008
bien vu !
merci !
Jacolin Yves a écrit :
> Hi,
> Mapserver is a SLD server by default (i mean no extra configuration, no extra
> build), just ask to mapserv cgi and you get it. The style is the one you
> setup in your LAYER CLASS object. You can even change it and send it back to
> mapserver to change the style of the LAYER.
> This is what I do for a simple map export to define the new opacity of the
> layer, opacity changed by my openLayer side.
> Y.
> Le Wednesday 12 March 2008 10:22:03 Guillaume Sueur, vous avez écrit :
>> Will that work if no SLD is yet associated to the mapfile and maplayer ?
>>> Hi,
>>> With a geStyle resquest, you get something like this for the polygon
>>> layer : <PolygonSymbolizer>
>>> <Fill>
>>> <CssParameter name="fill">#aaaa7f</CssParameter>
>>> </Fill>
>>> <Stroke>
>>> <CssParameter name="stroke">#000000</CssParameter>
>>> </Stroke>
>>> </PolygonSymbolizer>
>>> For a polyline layer:
>>> <LineSymbolizer>
>>> <Stroke>
>>> <CssParameter name="stroke-width">1</CssParameter>
>>> </Stroke>
>>> </LineSymbolizer>
>>> For a point layer:
>>> <PointSymbolizer>
>>> <Graphic>
>>> <Mark>
>>> <WellKnownName>circle</WellKnownName>
>>> <Fill>
>>> <CssParameter name="fill">#0000c8</CssParameter>
>>> </Fill>
>>> </Mark>
>>> <Size>5</Size>
>>> </Graphic>
>>> </PointSymbolizer>
>>> Y.
>>> Le Wednesday 12 March 2008 10:14:07 Guillaume Sueur, vous avez écrit :
>>>> which kind of SLD request ?
>>>> Actually, I need the geomType to specify which SLD template to associate
>>>> with the layer...
>>>>> Le Wednesday 12 March 2008 10:05:11 Guillaume Sueur, vous avez écrit :
>>>>>> Hi again,
>>>>>> I'm trying to use describeFeatureType to retrieve type and fields of a
>>>>>> given layer.
>>>>>> While it looks right for attibute data, the GeomType is not precise :
>>>>>> <element name="msGeometry" type="gml:GeometryPropertyType"
>>>>>> minOccurs="0" maxOccurs="1"/>
>>>>>> The only piece of information I get in there is that the Geometry is
>>>>>> of GeometryType, which I don't need any WFS request for !
>>>>>> Is there a specific METADATA item to add or use to be able to have the
>>>>>> precise type (PolygonPropertyType for instance) ?
>>>>>> Thanks,
>>>>> Hi Guillaume,
>>>>> You can use a SLD request on the layer.
>>>>> Y.
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 74 91 95 20
Site web : http://www.neogeo-online.net
