[mapserver-users] MapServer 4.8.3: MapScript setProjection
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Mar 12 09:54:53 EDT 2008
> > Excuse the stupid question, but what do you mean by native PROJ4
definition? Do you mean applying the inline parameters directly?
> He means giving the projections with the actual strings which are
also hidings behind the epsg codes,
> for example this means the same as epsg:2393PROJECTION "+proj=tmerc
+lat_0=0 +lon_0=27 +k=1.000000
> +x_0=3500000 +y_0=0 +ellps=intl
+towgs84=-90.7,-106.1,-119.2,4.09,0.218,-1.05,1.37 +units=m +no_defs"
> Projection strings are slower to write int mapfile but for Mapserver
they are faster to execute because these is
> no need to jump to projection library file. If you have MS4W
installation you can find the strings to use from
> D:\ms4w\proj\nad directory, most of them from file names epsg.
Excuse the stupid answer, you were asking about MapScript which I know
nothing about. Basically it must be
about the same thing, though.
-Jukka-
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080312/b0533f73/attachment.html
