[mapserver-users] MapServer 4.8.3: MapScript setProjection
Daniel Morissette
dmorissette at mapgears.com
Wed Mar 12 10:29:55 EDT 2008
Rahkonen Jukka wrote:
> > > Excuse the stupid question, but what do you mean by native PROJ4
> definition? Do you mean applying the inline parameters directly?
>> He means giving the projections with the actual strings which are also
> hidings behind the epsg codes,
>> for example this means the same as epsg:2393PROJECTION "+proj=tmerc
> +lat_0=0 +lon_0=27 +k=1.000000
>> +x_0=3500000 +y_0=0 +ellps=intl
> +towgs84=-90.7,-106.1,-119.2,4.09,0.218,-1.05,1.37 +units=m +no_defs"
>> Projection strings are slower to write int mapfile but for Mapserver
> they are faster to execute because these is
>> no need to jump to projection library file. If you have MS4W
> installation you can find the strings to use from
>> D:\ms4w\proj\nad directory, most of them from file names epsg.
> Excuse the stupid answer, you were asking about MapScript which I know
> nothing about. Basically it must be
> about the same thing, though.
Your answer applies to MapScript as well. In the MapScript case you'd do:
$map->setProjection("+proj=tmerc +lat_0=0 +lon_0=27 +k=1.000000
Daniel
Daniel Morissette
http://www.mapgears.com/
