[mapserver-users] Farsi right-to-left labels
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Mar 12 19:12:29 EDT 2008
Yes, I have used arabjoin.pl for the perl version
http://user.cs.tu-berlin.de/~czyborra/arabjoin/arabjoin
and I just started looking for a C langauge version and there a few
variations based on:
http://www.koders.com/c/fid0CDEEAE48A82518AB622E67323B84AB525772AED.aspx?s=mp3
http://www.koders.com/c/fidD92D7571C80226F5F767189298750ACC8461B090.aspx?s=mp3
http://www.koders.com/c/fid6998723CE404855329383741EACE2197511ACDB6.aspx?s=mp3
This is a variation on the above but has a more complete and useful
example, and it will also handle Hebrew, Arabic, and maybe Farsi
http://www.google.com/url?sa=t&ct=res&cd=1&url=http%3A%2F%2F130.89.160.166%2Frockbox%2Farabjoin.c&ei=rlPYR6-8DZjEgQT43tymBQ&usg=AFQjCNFUtcluvex5eicUU4b70H_ok5vC7Q&sig2=m8TZs2uMbL8Te8f2Za0fVQ
http://www.google.com/search?num=100&hl=en&lr=&as_qdr=all&q=arabjoin.c++stdbool.h
-Steve W.
Yewondwossen Assefa wrote:
> Stephen Woodbridge wrote:
>> Hi Daniel,
>> I looked at the patch briefly.
>> It doesn't seem to be doing character joining for works in Arabic.
>> I'm thinking that if we had the algorithm to do the joining then we
>> could add that and maybe a Tag or metadata item that enabled the
>> joining if needed. The joining algorithm, might be smart enough to
>> only join Arabic letters and leave the rest alone.
>> If you are interested, I think I can get my hands on a perl script
>> that does the joining.
> Steve,
> Isn't is what the function shape_arabic (from the PostArabic) module
> does? If that is the case, the source code in C and an original perl
> source code are available on the web.
> Best Regards,
>> -Steve W
>> Daniel Morissette wrote:
>>> Copying what I wrote earlier this morning on the ka-map list (sorry
>>> for those on both lists):
>>> FYI there is an open MapServer ticket about this:
>>> http://trac.osgeo.org/mapserver/ticket/956
>>> The ticket even includes a patch that you may want to try. I'll try
>>> to address this one for MapServer 5.2.
>>> Daniel
>>> R Isfahani wrote:
>>>> Hi,
>>>> I'm trying to render some Farsi (Persian) labels on my map. As you
>>>> may know, Farsi words are written from right to left, just like Hebrew.
>>>> I've changed the label's encoding to 'Windows-1256' in my mapfile
>>>> and I'm using TrueType fonts. Farsi letters have appeared. But the
>>>> problem is that letters are in revers order and letters are not
>>>> joining properly.
>>>> Of course reversing the letters' order in database will cause the
>>>> right order of them when rendering the map. But I wanna know if
>>>> there's any other way to show farsi labels in right order with no
>>>> joining problems.
>>>> [Actually, I'm using Ka-Map on the top of Mapserver to render my
>>>> maps on the web. Ka-Mappers told me that my problem is a kind of
>>>> Mapserver problems]
>>>> Any new ideas are welcomed.
>>>> Thanx.
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
