[mapserver-users] GPX file viewer with mapserver
Tran Tho Ha
vncntt at gmail.com
Sat Mar 15 19:31:47 EDT 2008
Thanks Frank for your advice.
I identified that I was using old version of MS4W. So when I upgrade to MS4W
2.2.7, it works. At least, the errors I mentioned before didn't occurred
anymore. But I have another problem: I only get a blank image, instead of a
map. Can you suggest which things should I check for this error?
On Fri, Mar 14, 2008 at 1:47 AM, Frank Warmerdam <warmerdam at pobox.com>
wrote:
> Alexander,
> I believe GPX support was introduced into OGR in the 1.5.0 release, and
> it is only enabled for reading in builds that include the Expat XML
> parser.
> I would suggest you try it at the commandline with ogrinfo:
> ogrinfo -al test.gpx
> I'd add the error report does not seem to indicate any path, so there
> may be a path problem. You might want to try with a full path from
> the root, and see if that works.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080316/03e9d4b1/attachment.html
