[MAPSERVER-USERS] Fwd: CLOSE_CONNECTION=DEFER - Segmentation fault
Ivan Mincik
ivan.mincik at gmail.com
Tue Mar 18 03:34:19 EDT 2008
On Tuesday 18 March 2008 02:26, rich.fromm wrote:
> Dave Fuhry wrote:
> > Oops, forgot to CC mapserver-users.
> > ---------- Forwarded message ----------
> > From: Dave Fuhry <dfuhry at gmail.com>
> > Date: Wed, Mar 12, 2008 at 6:33 PM
> > Subject: Re: [MAPSERVER-USERS] CLOSE_CONNECTION=DEFER - Segmentation
> > fault To: Ivan Mincik <ivan.mincik at gmail.com>
> > So essentially, the patch should be modified to remove the ROLLBACKs
> > from msPOSTGISLayerGetShape() in a safe way.
> Just to make sure I'm properly interpreting the status of what's getting to
> be a bit of a long thread here...
> You're saying that this patch:
> http://trac.osgeo.org/mapserver/attachment/ticket/2497/ms_postgis_begin_to_
>connect.diff from this bug:
> http://trac.osgeo.org/mapserver/ticket/2497
> is not entirely correct and should be modified?
I have applied this patch and it is not properly working when using
{map,layer}Obj_queryBy{Point,Rect,etc.} functions. This was confirmed by Dave
Fuhry.
> But this change has not happened yet, I gather?
I don't know about any other patch.
> I assume that if/when there's a new patch, notice will be posted either in
> this mailing list thread or that bug?
Yes. I am looking for the notice here in the mailinglist and to the bug
thread.
> I ask b/c I build mapserver from source and am currently using that patch,
> and I want to make sure I recompile if that patch changes.
I want to recompile mapserver with the patch which is correctly working with
So, I think the status of this problem is "waiting for the new patch".
Ivan
> Thanks.
> - Rich
