[mapserver-users] AGG vs. GD: Label placement problems
thomas bonfort
thomas.bonfort at gmail.com
Tue Mar 18 08:10:20 EDT 2008
http://trac.osgeo.org/mapserver/ticket/2357
On Tue, Mar 18, 2008 at 1:05 PM, Doyon, Jean-Francois
<jdoyon at nrcan.gc.ca> wrote:
> Thanks Thomas, that'd be great ... is there a ticket open for this, or
> should I open one? (I'd like to track progress on this issue ...)
> J.F.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of thomas
> bonfort
> Sent: March 18, 2008 03:42
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] AGG vs. GD: Label placement problems
> Yes, that's exactly the problem, as there's a difference of a few pixels
> between the size of the label calculated by gd and the size it actually
> takes when rendered with agg. I realize now that it can cause some quite
> visible problems in the case you show here (labels to the left), as in
> that case the few pixels difference can cause the label to overlap the
> point symbol. I'll see if I can fix this in the days/weeks to come so
> this can be included in 5.2
> cheers,
> thomas
> On Mon, Mar 17, 2008 at 8:25 PM, Daniel Morissette
> <dmorissette at mapgears.com> wrote:
> > Doyon, Jean-Francois wrote:
> > > Labels that are to the left of the point seem to be placed
> differently ... Look top-right ("Les Escoumins", "Saint Anne de Port
> Neuf", etc ...) for an example, though it happens all over the place I
> think. Labels to the right of the point however seem ok.
> > > Is this a bug? A design change? Can anything be done from the
> mapfiel to mitigate this?
> > A few days ago, ThomasB wrote on mapserver-dev that in AGG mode, "gd
> > is still used [...] for the calculation of label sizes (thus some
> > subtle discreptancies in label placement, mostly visible if using a
> > label
> > backgroundcolor)":
> > http://lists.osgeo.org/pipermail/mapserver-dev/2008-March/006868.html
> > Maybe that's what your running into? Hopefully Thomas will see this
> > and comment.
> > Daniel
> > Daniel Morissette
> > http://www.mapgears.com/
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
