[mapserver-users] Mapfile for getFeatureInfo
Luca Casagrande
luca.casagrande at gmail.com
Fri Mar 21 04:10:53 EDT 2008
Hi Milo,
On Friday 21 March 2008 09:02:15 Milo van der Linden wrote:
> The problem is with:
> DATA 'the_geom FROM manis.stations'
> it has to be something like:
> DATA 'the_geom from (select
> station_id,param1,param2,param3,param4,the_geom from manis.stations) as
> stats using unique station_id using SRID=4326'
> You have to explicitly address the fields you want to be available in
> your DATA statement.
Thank you very much, this worked like a charm !
Bye
Luca
