[mapserver-users] upload/stream data from GPS unit?
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Mar 27 16:42:18 EDT 2008
Bill Wordsworth wrote:
> Thanks Steve. I am clear about the mapping part. I am not so sure about
> streaming/uploading near-real-time GPS data from on-site to webserver
> across WPA?
I can not speak to WPA, I'm not sure I know that protocol, but if have a
cell phone that that can do HTTP GET requests to a server, you can
trivially write a php page the gets the url and writes the fields to a
database and have mapserver display that. So that is pretty real-time.
So you phone would ping a url like
http://yourserver.com/track.php?lat=<lat>&lon=<lon>&device=<uid>&...
And then write a track.php to fetch the paramaters and stuff them into
the DB.
-Steve W
> Cheers, Bill
> On Thu, Mar 27, 2008 at 3:10 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> Bill,
> There are probably many solutions available depending on the various
> technical components that you might have in the solution. One possible
> solution might be something along these lines:
> 1) stream data to some service that you probably have to build
> 2) have said service load the points into a postgres/postgis database
> 3) create a mapfile with a LAYER to disply the data from postgis
> 4) Use a client like OpenLayers to render you map from mapserver
> 5) add a timer event to refresh your map every X secs
> -Steve W
> http://imaptools.com/
> > Please let's not hijack my poor thread :)! Anyway, here's my original
> > question:
> > "How can I upload/stream near-real-time GPS data from on-site to
> > webserver/MapServer (MapServer 5.x can read *.gpx)?"
> > I've been referred to http://franson.com/gpsgate/ from the usenet
> > groups. I am looking for something with WPA.
> > Cheers, Bill
> > On Wed, Mar 26, 2008 at 11:39 AM, Carlos Pinto
> <cmspinto at gmail.com <mailto:cmspinto at gmail.com>
> > <mailto:cmspinto at gmail.com <mailto:cmspinto at gmail.com>>> wrote:
> > Hi all,
> > I'm new in MapServer and I'm using Openlayers that can be a
> client
> > of MapServer.
> > What I'm trying to set-up is a grid that is in GML file. And
> I want
> > MapServer to build the layer reading the GML file and give it to
> > OpenLayers (javascript API) would read it as WMS.
> > I have instaled MapServer in C# so I'm using MapScript. Is this
> > possible?
> > Thanks
> > Carlos
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> <mailto:mapserver-users at lists.osgeo.org>>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > On Wed, Mar 26, 2008 at 11:25 AM, Bill Wordsworth
> > <bill.wordsworth at gmail.com <mailto:bill.wordsworth at gmail.com>
> > Cheers, Bill
