[MAPSERVER-USERS] CLOSE_CONNECTION=DEFER - Segmentation fault
Carlos_Molina
dr.chamberlain at gmail.com
Thu Mar 27 17:16:11 EDT 2008
Dave Fuhry wrote:
> Ivan,
> p.mapper seems to use the typical php
> {map,layer}Obj_queryBy{Point,Rect,etc.} functions. These calls end up
> calling the same msPOSTGIS* functions as everything else.
> I can't seem to reproduce your problem with a simple testcase
> (basically, the attached files). It might help if you can set
> log_min_duration_statement = 0 in your postgresql.conf, reproduce the
> problem, and send the output from your postgresql log file. It will
> show all commands issued to the database, including the BEGIN, and the
> DECLARE CURSOR ..., and FETCH for every layer.
> I can setup p.mapper if that's necessary to reproduce the problem.
> (By the way, I assume you're not using an ancient version of
> postgis, in the 0.5 - 0.6 era. There is an alternate codepath for
> that, which I have not tested.)
> Thanks,
> Dave
Hello Dave,
I've tried first and second version of your patch and both resolved my first
issue of many many BEGIN statements being issued by cursors so my
application went back to running smoothly. The sad part is that another
issued arised from this patch and It's when using python mapscript and the
drawQuery call.
If i just render my .map file with draw() I get no trouble, but if I open my
map file, get a single layer from it, query the layer, open the layer to
retrieve results and call drawQuery() afterwards to render everything like I
used to do before the patch, I get the following error(I resumed the sql
statements):
BEGIN
DECLARE mycursor BINARY CURSOR FOR SELECT... // queryByPoint
FETCH ALL in mycursor
CLOSE mycursor
SELECT * FROM... "same as above" WHILE false LIMIT 0 // Dont know why this
is issued, might be openLayer or just to get the field names of the table
WARNING: there is already a transaction in progress
BEGIN
DECLARE mycursor2 BINARY CURSOR FOR SELECT... // getShape(0)
FETCH ALL in mycursor2
CLOSE mycursor2
ROLLBACK
BEGIN
DECLARE mycursor2 BINARY CURSOR FOR SELECT... // getShape(1)
CLOSE mycursor2
ROLLBACK
ERROR: DECLARE CURSOR may only be used in transaction blocks
WARNING: there is no transaction in progress
statement: rollback
statement: begin
ERROR: cursor "mycursor" does not exist
ABORT
Regards
Carlos Molina
View this message in context: http://www.nabble.com/CLOSE_CONNECTION%3DDEFER----Segmentation-fault-tp15786741p16333076.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
