[mapserver-users] Label Follows streets alignment issue
thomas bonfort
thomas.bonfort at gmail.com
Fri Mar 28 04:57:02 EDT 2008
Steve,
I haven't noticed anything special, nor do I really understand what
problem you mention.
attached is a test image I used to check. do you see anything wrong in it?
could you make a minimal test case to reproduce, or attach an image
showing the problem?
cheers,
thomas
Thomas Bonfort
Camptocamp France SAS
Tel : +33 (0)4 79 26 57 97
thomas dot bonfort at camptocamp dot com
http://www.camptocamp.com
On Fri, Mar 28, 2008 at 5:57 AM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Hi Thomas,
> I have noticed that labels in a google style symbology that follow a
> straight line segment at approximately 45 degrees upper left to lower
> right and slightly off being aligned with the street.
> It is just enough to be annoying once you notice it.
> Have you noticed this?
> Can this be fixed?
> Thanks in advance,
> -Steve W
> mapserver-users at lists.osgeo.org
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080328/8a39e668/bug-0001.png
