[MAPSERVER-USERS] agg and line widths
thomas bonfort
thomas.bonfort at gmail.com
Mon Mar 31 03:49:02 EDT 2008
hi,
you're probably drawing polygons with adjacent borders right?
in this case, each line except the outer ones is drawn twice, and thus
its final width is larger than what is requested.
I don't think there's much you can do about it except preprocess your
data to transform it into a line layer with no duplicates.
cheers,
Thomas Bonfort
Camptocamp France SAS
Tel : +33 (0)4 79 26 57 97
thomas dot bonfort at camptocamp dot com
http://www.camptocamp.com
On Sat, Mar 29, 2008 at 1:22 PM, DNC <dncarreira at gmail.com> wrote:
> Hi.
> I'm having trouble getting thin lines to draw. The thinnest line I get seems
> to be 2 pixels wide at least. Using GD the lines are indeed 1 pixel. Anyone
> can point out why this happens?
> Some sections from the map file:
> OUTPUTFORMAT
> NAME 'AGG_Q'
> DRIVER AGG/PNG
> MIMETYPE "image/png"
> IMAGEMODE RGB
> FORMATOPTION "QUANTIZE_FORCE=ON"
> FORMATOPTION "QUANTIZE_DITHER=OFF"
> FORMATOPTION "QUANTIZE_COLORS=256"
> END
> LAYER
> NAME 'test'
> GROUP "test group"
> TYPE POLYGON
> #MINSCALE 250000
> CONNECTIONTYPE postgis
> CONNECTION 'bla'
> PROCESSING "CLOSE_CONNECTION=DEFER"
> DATA 'the_geom from table using unique gid'
> #FILTER ''
> METADATA
> 'wms_title' 'some layer'
> "ows_abstract" "some text"
> 'wms_srs' 'EPSG:27492'
> "wms_opaque" "0"
> "wms_group_title" "group title"
> "wms_group_abstract" "group text"
> END
> STATUS ON
> TRANSPARENCY 100
> PROJECTION
> 'init=epsg:27492'
> END
> EXTENT -23893.143277 -173568.018533 62541.864515 -70038.622014
> MINSCALE 1
> # MAXSCALE 100000
> # data is queryable
> DUMP TRUE
> HEADER /ms_ogc_workshop/templates/rivers_query_header.html
> TEMPLATE /ms_ogc_workshop/templates/rivers_query_body.html
> # fuzziness for querying
> TOLERANCE 5
> CLASS
> NAME 'outlines'
> STYLE
> WIDTH 1
> OUTLINECOLOR 232 232 232
> END
> END
> END
> Regards,
> Duarte
> View this message in context: http://www.nabble.com/agg-and-line-widths-tp16369480p16369480.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
