[mapserver-users] install ms4w
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sat Nov 1 16:52:41 EDT 2008
My recommendation is to go on with the easiest way, which for my mind is MS4W. Just make Apache run, it is for sure possible.
Possible reasons for Apache not starting with "apache-install.bat" include:
- port 80 is reserved for some other service
solution: edit C:\ms4w\Apache\conf}httpd.conf and use some other port
- your user rights do not allow you to install Apache as service
solution: start Apache as program from C:\ms4w\Apache\bin\httpd.exe
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: cemre yilmaz
Lähetetty: la 1.11.2008 20:43
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] install ms4w
Hello everybody I have a problem with installation of MS4W. I follow the
instructions on new users tab on MapServer web site. But the apache server
didin't start.
- So I have downloaded apache 2.2.10 web server from the apace web site and
installed it. It is running.
- Then I have installed OSGeo4W map server I have tested it writing mapserv
-v in the command line and it is also running.
After those installation I have tried the ms4w workshop documentation and
tutorial for some exercise but none of them has worked.
I have copied the course tutorial data in the C: drive of my computer. And I
have pointed the file "http://localhost/ms101/vector_index.html" but it
didn't work
Do you have any idea what is wrong with the installation? Please write me
soon it is important for my thesis.
