[mapserver-users] Re: GDAL and SDE raster
Liz Godwin
godwin.liz at gmail.com
Tue Nov 4 13:36:58 EST 2008
tried this but I don't know how to get it to work with mapserver.
On Tue, Nov 4, 2008 at 10:13 AM, Lucena, Ivan <ivan.lucena at pmldnet.com>wrote:
> Ron,
> Some raster driver in GDAL are not flie based but RDBMS based but most of
> the softwares based on GDAL did not
> noticed that change. In those case, instead of a file path what you need is
> a identification string but those software
> usually have code to grab the file path, to check if the file really exist,
> to check other files on the same folder and
> that is where it crashes.
> What I suggest to Liz is to use a VRT file instead of the identification
> string. As you might know, a VRT file does not
> contain the data but a path to the real data set.
> I use that trick to load images direct from the RDBMS server to OpenEv and
> QuantumGIS:
> % gdal_translate -of VRT <the identification string of your dataset>
> <temporary.vrt>
> ... check if it works:
> % gdalinfo <temporary.vrt>
> ... check what is inside it:
> % more <temporary.vrt>
> ... load it:
> % openev <temporary.vrt>
> % qgis
> ... click on add layer
> ... select your <temporary.vrt>
> I thought that it would work for mapserve too...
> /filepath/<temporary.vrt>
> But Liz tried and said it doesn't. Too bad, I was counting on it. ;(
> Regards,
> Ivan
> > -------Original Message-------
> > From: Ron Goldman <ron at ocean.org.il>
> > Subject: [mapserver-users] Re: GDAL and SDE raster
> > Sent: Nov 04 '08 14:01
> > I had a similar problem with NetCDF raster. It probably won't help much
> for SDE
> > but make sure you have absolute filepath after the "SDE:" and not before
> it.
> > Date: Tue, 4 Nov 2008 08:24:52 -0500
> > From: "Liz Godwin" <godwin.liz at gmail.com>
> > Subject: Re: [mapserver-users] GDAL and SDE raster
> > To: "Lucena, Ivan" <ivan.lucena at pmldnet.com>
> > Cc: eidsnessl at agr.gc.ca, mapserver-users at lists.osgeo.org,
> > whittekerc at agr.gc.ca
> > Message-ID:
> > <d33d7cc00811040524o6642e27w234e060f5ed87cd4 at mail.gmail.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > Thank you, but that option doesn't appear to work for Raster data types.
> > Liz
> > On Mon, Nov 3, 2008 at 7:40 PM, Lucena, Ivan <ivan.lucena at pmldnet.com
> >wrote:
> > > > I don't have SDE to tell you the truth but I would suggest you to
> create a
> > > > VRT version of your dataset and use the VRT on your map file. [
> > > > gdal_translate -of vrt
> > > > /filepath/SDE:server,port:5151,sde,user/pass,schema.table,RASTER
> > > > replacement.vrt ]
> > >> > > From: Liz Godwin <godwin.liz at gmail.com>
> > >> > > Subject: [mapserver-users] GDAL and SDE raster
> > >> > > Sent: Nov 03 '08 22:19
> > >> > > Hey folks,
> > >> > > We've been beating ourselves up over this problem and I'm not
> sure
> > >> > > what to try next.
> > >> > > We can't seem to connect to SDE for a raster using GDAL in
> mapserver.
> > >> > > This is happening on Linux.
> > >> > > snippit from mapfile:
> > >> > > TYPE RASTER
> > >> > > DATA "SDE:server,port:5151,sde,user,pass,schema.table,RASTER"
> > >> > > when trying to draw a map, i get a seg fault. When trying a
> > >> > > getFeatureinfo request, I get this error:
> > >> > > /filepath/SDE:server,port:5151,sde,user: Image handling error.
> Unable to
> > >> > > open file LayerName for layer
> > `/filepath/SDE:server,port:5151,sde,user/pass,schema.table,RASTER' does
> > >> > > not exist in the file system, and is not recognised as a
> supported
> > > > dataset
> > >> > > name.
> > >> > > ... fatal error.
> > >> > > msRasterQueryByRect()
> > >> > > Any ideas how I might start to debug this? I have DEBUG set to
> 5 in
> > > > both
> > >> > > the LAYER and MAP object in the map file.
> > >> > > Thanks!
> > >> > > Liz
> > >> > > _______________________________________________
> > >> > > mapserver-users mailing list
> > >> > > [LINK: compose.php?to=mapserver-users at lists.osgeo.org]
> > >> > > [LINK: http://lists.osgeo.org/mailman/listinfo/mapserver-users]
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL:
> http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081104/fee291c7/attachment.html
> > This outgoing email was scanned for viruses and other malicious content
> by the IT Department of Israel
> Oceanographic & Limnological Research.
> > AntiVirus system managed by Eli W. Tel. 972-4-8565267
> > IMPORTANT: Do not open attachments from unrecognized senders.
> > Never open attached files with extensions: *.pif, *.scr, *.vbs, *.exe.
> ***********************************************************________________________________
> _______________
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081104/c787ba63/attachment-0001.html
