[mapserver-users] Map Labels Problem
Kusum
kusum at infobase.in
Thu Nov 6 23:17:59 EST 2008
Dear All
I am trying to use mercator projection in my mapfile.
Also I am using a raster image along with my shp data
At first level it does not show the raster image
But when it does it hides the labels on map.
u can see this link
http://mapxl.com/interactive-maps/world-map11.php
I am confused
my map file is
MAP
EXTENT -180 -90 180 90
UNITS MILES
SIZE 550 450
SHAPEPATH "/home/mapxlco/public_html/World-Data"
FONTSET "./etc/fonts.txt"
RESOLUTION 96
IMAGETYPE png
INTERLACE OFF
PROJECTION
"proj=merc"
#'init=EPSG:3785'
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
FORMATOPTION INTERLACE=OFF
TRANSPARENT OFF
END
WEB
TEMPLATE "legend.php"
HEADER "map_header.html"
FOOTER "map_footer.html"
#IMAGEPATH "C:/ms4w/apps/maplab-2.2/workshop/tmp/"
#IMAGEURL "../tmp/"
IMAGEPATH "/home/mapxlco/public_html/tmp/"
IMAGEURL "/tmp/"
METADATA
END # Metadata
END
#World_Background
LAYER
NAME "background"
STATUS DEFAULT
PROJECTION
#"init=epsg:3785"
END
TYPE POLYGON
DATA "background"
TOLERANCE 300
#CLASSITEM "COUNTRIES"
CLASS
NAME "World Background"
COLOR 141 189 232
OUTLINECOLOR 111 157 253
Template void
END
END
#World Continents
LAYER
NAME "continents"
STATUS DEFAULT
PROJECTION
#"init=epsg:3785"
END
TYPE POLYGON
DATA "World_Continents"
MINSCALE 1500000
LABELMAXSCALE 2500000
LABELMINSCALE 1430359
LABELITEM "CONTINENT"
TOLERANCE 300
CLASSITEM "CONTINENT"
CLASS
NAME "World Outline"
EXPRESSION "Europe"
#COLOR 241 238 232
COLOR 235 240 230
LABEL
ANGLE auto
ANTIALIAS TRUE
FONT arial
MAXSIZE 256
MINSIZE 4
SIZE 10
TYPE TRUETYPE
BUFFER 0
COLOR 0 0 0
FORCE TRUE
MINDISTANCE 0
MINFEATURESIZE 0
OFFSET 0 10
OUTLINECOLOR 255 255 255
PARTIALS FALSE
POSITION LL
END
Template void
END
CLASS
EXPRESSION "North America"
#COLOR 241 238 232
COLOR 235 240 230
LABEL
ANGLE auto
ANTIALIAS TRUE
FONT arial
MAXSIZE 256
MINSIZE 4
SIZE 10
TYPE TRUETYPE
BUFFER 0
COLOR 0 0 0
FORCE TRUE
MINDISTANCE 0
MINFEATURESIZE 0
OFFSET 20 10
PARTIALS FALSE
POSITION LR
END
Template void
END
CLASS
#COLOR 241 238 232
COLOR 235 240 230
LABEL
ANGLE auto
ANTIALIAS TRUE
FONT arial
MAXSIZE 256
MINSIZE 4
SIZE 10
TYPE TRUETYPE
BUFFER 0
COLOR 0 0 0
FORCE TRUE
MINDISTANCE 0
MINFEATURESIZE 0
OFFSET 0 0
PARTIALS FALSE
POSITION CC
END
Template void
END
END
#World Countries
LAYER
NAME "countries"
STATUS DEFAULT
MAXSCALE 1530359
LABELMAXSCALE 1430359
PROJECTION
#"init=epsg:3785"
END
TYPE POLYGON
DATA "World_Countries"
LABELITEM "NA2DESC"
TOLERANCE 300
CLASSITEM "NA2DESC"
CLASS
NAME "World Countries"
#COLOR 241 238 232
COLOR 235 240 230
OUTLINECOLOR 220 220 220
LABEL
ANGLE auto
ANTIALIAS TRUE
FONT arial-bold
MAXSIZE 256
MINSIZE 4
SIZE 9
TYPE TRUETYPE
BUFFER 0
COLOR 90 90 90
MINDISTANCE 0
MINFEATURESIZE 30
OFFSET 0 0
PARTIALS FALSE
POSITION CC
FORCE FALSE
wrap ' '
END
Template void
END
END
#World_Background
LAYER
NAME "background1"
STATUS ON
PROJECTION
"proj=latlong"
END
TYPE RASTER
DATA "wsiearth.tif"
TEMPLATE "ttt.html"
END
#Countries Boundary
LAYER
NAME "countries"
STATUS DEFAULT
MAXSCALE 1430359
PROJECTION
#"init=epsg:3785"
END
TYPE LINE
DATA "Country_Boundary"
TOLERANCE 300
#CLASSITEM "CONTINENT"
CLASS
#COLOR 204 225 253
OUTLINECOLOR 167 167 167
Template void
END
END
so on..........
I am not getting the palce of error
Please suggest.
Regards
Kusum
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081107/aa81a02f/attachment.html
