[mapserver-users] Adding symbols on top of polyline elements
Adrian Popa
adrian_gh.popa at romtelecom.ro
Mon Nov 10 06:01:19 EST 2008
Hello Thomas,
Thank you very much for your tip! It's great.
However, I have a question: How can I select the direction of the arrow?
I mean, between A and B I have a road segment:
A----------------B
Right now, it renders as A---->---->----->-----B, but I want it to
render as A----<------<-----<------B.
My question is: how does mapserver select the order of A and B? If I
understand this, I can create another symbol and use it for the reverse
path.
Thanks,
Adrian
thomas bonfort wrote:
> Hi,
> for repeated arrow symbols, you can use a truetype (or image, or
> vector) symbol, with a negative GAP:
> SYMBOL
> NAME oneway
> TYPE TRUETYPE
> CHARACTER '>'
> FONT arial
> GAP -20
> END
> and then in your layer:
> STYLE
> SYMBOL oneway
> SIZE 8
> COLOR 0 0 0
> END
> cheers,
> thomas
> On Mon, Nov 10, 2008 at 10:51, Adrian Popa <adrian_gh.popa at romtelecom.ro> wrote:
>> Hello everybody,
>> I have a map that displays roads stored in a polyline format. I would like
>> to mark one-way streets with an arrow symbol drawn on top of the road
>> itself. The symbol can be as small as possible (for beginning I would like
>> to be able to superimpose it anywhere between the street ends, and later on
>> I will lock it to be next to one of the ends).
>> I can already select the one way streets based on the following template:
>> CLASS
>> Name "OneWay"
>> EXPRESSION
>> /^FO040127$|^FO040132$|^FO040139$|^FO040120$|^FO040104$|^FO040131$|^FO040146$|^FO040129$/
>> STYLE
>> COLOR 255 0 0
>> WIDTH 4
>> END
>> LABEL
>> COLOR 0 0 255
>> TYPE TRUETYPE
>> FONT arial
>> SIZE 8
>> ANTIALIAS TRUE
>> POSITION AUTO
>> ANGLE AUTO
>> PARTIALS TRUE
>> MINDISTANCE 0
>> BUFFER 0 END
>> END
>> Can you show me an example of how to draw such a symbol on top of the layer?
>> Thank you
>> Adrian
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Adrian Popa
Network Engineer
Romtelecom S.A.
Divizia Centrul National de Operare Retea
Departament Transport IP & Metro
Compartiment IP Core
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081110/938b4f9d/attachment.html
