[mapserver-users] Adding symbols on top of polyline elements
Adrian Popa
adrian_gh.popa at romtelecom.ro
Mon Nov 10 06:44:02 EST 2008
Can you please clarify to me what you mean by data that is oriented?
When I built the road layer from GPS data, I added polylines starting
from point A->...->B and recorded all the inflections in the road
between A and B.
By ordered data you mean the direction in this case is A->B?
If I wanted to reverse the direction I'd have to write the data to the
shapefile in the order B->A?
Thanks
thomas bonfort wrote:
> it's the direction of the underlying geometry that's used.
> so you either need
> * data that's oriented, and a single boolean filed indicating if its
> oneway or not,
> * or an unoriented geometry, and a field indicating if the oneway
> direction is reversed or not wrt the geometry (and two directional
> symbols, one with > , the other with <)
> cheers,
> thomas
> On Mon, Nov 10, 2008 at 12:01, Adrian Popa <adrian_gh.popa at romtelecom.ro> wrote:
>> Hello Thomas,
>> Thank you very much for your tip! It's great.
>> However, I have a question: How can I select the direction of the arrow? I
>> mean, between A and B I have a road segment:
>> A----------------B
>> Right now, it renders as A---->---->----->-----B, but I want it to render as
>> A----<------<-----<------B.
>> My question is: how does mapserver select the order of A and B? If I
>> understand this, I can create another symbol and use it for the reverse
>> path.
>> Thanks,
>> Adrian
>> Hi,
>> for repeated arrow symbols, you can use a truetype (or image, or
>> vector) symbol, with a negative GAP:
>> SYMBOL
>> NAME oneway
>> TYPE TRUETYPE
>> CHARACTER '>'
>> FONT arial
>> GAP -20
>> END
>> and then in your layer:
>> STYLE
>> SYMBOL oneway
>> SIZE 8
>> COLOR 0 0 0
>> END
>> cheers,
>> thomas
>> On Mon, Nov 10, 2008 at 10:51, Adrian Popa <adrian_gh.popa at romtelecom.ro>
>> wrote:
>> Hello everybody,
>> I have a map that displays roads stored in a polyline format. I would like
>> to mark one-way streets with an arrow symbol drawn on top of the road
>> itself. The symbol can be as small as possible (for beginning I would like
>> to be able to superimpose it anywhere between the street ends, and later on
>> I will lock it to be next to one of the ends).
>> I can already select the one way streets based on the following template:
>> CLASS
>> Name "OneWay"
>> EXPRESSION
>> /^FO040127$|^FO040132$|^FO040139$|^FO040120$|^FO040104$|^FO040131$|^FO040146$|^FO040129$/
>> STYLE
>> COLOR 255 0 0
>> WIDTH 4
>> END
>> LABEL
>> COLOR 0 0 255
>> TYPE TRUETYPE
>> FONT arial
>> SIZE 8
>> ANTIALIAS TRUE
>> POSITION AUTO
>> ANGLE AUTO
>> PARTIALS TRUE
>> MINDISTANCE 0
>> BUFFER 0 END
>> END
>> Can you show me an example of how to draw such a symbol on top of the layer?
>> Thank you
>> Adrian
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Adrian Popa
>> Network Engineer
>> Romtelecom S.A.
>> Divizia Centrul National de Operare Retea
>> Departament Transport IP & Metro
>> Compartiment IP Core
Adrian Popa
Network Engineer
Romtelecom S.A.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081110/69b5d980/attachment.html
