[mapserver-users] How to set SCALEBAR size and intervals
in MapServer CGI >5.0?
Venkat Rao Tammineni
vtammineni at roulacglobal.com
Wed Nov 12 07:37:38 EST 2008
Here two ways where you can show scalebar. One is through mapfile and
another through Coding(C#, what I am using).
Thanks
Venkat.
-----Original Message-----
Sent: Wednesday, November 12, 2008 6:01 PM
To: Venkat Rao Tammineni; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] How to set SCALEBAR size and intervals in
MapServer CGI >5.0?
Thanks, but I know all of that already and am already aware of
MapServer's online references and am an experienced user. I also know
about the CGI reference that describes how to change map file parameters
via a URL in >5.0 versus <5.0:
http://mapserver.gis.umn.edu/docs/reference/cgi/referencemanual-all-pages
On further investigation, I've discovered that I must specify a map file
parameter as so in an HTTP GET request:
map_scalebar=size+width+height+intervals+value
But alternatively, I must use a different method for specifying these
map file parameters in an HTTP POST request:
map_scalebar_size=width+height
map_scalebar_intervals=value
This requires me to code for two different scenarios. Is MapServer's
intended behavior or is this an oversight/bug?? Thanks!
Cheers,
John Maurer
Venkat Rao Tammineni wrote:
> HI,
http://mapserver.gis.umn.edu/docs/reference/mapfile/scalebar/?searchterm=sca
> lebar
> check above url.
> Thanks,
> Venkat
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of John Maurer
> Sent: Wednesday, November 12, 2008 5:50 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] How to set SCALEBAR size and intervals in
> MapServer CGI >5.0?
> Dear MapServer Users,
> Prior to MapServer 5.0, I could set the map scalebar size and intervals
> using CGI variables named "map_scalebar_size" and
> "map_scalebar_intervals". After upgrading to 5.2.0, however, these
> variables are no longer recognized; I get an error saying
> "loadScalebar(): Unknown identifier". Is it true that we can no longer
> reference map settings in this fashion? When I change these variables to
> "map_scalebar=size+value+intervals+value" it works, but this no longer
> fills in my template variables [map_scalebar_size] and
> [map_scalebar_intervals]. If I try using a template variable with
> [map_scalebar] instead, the value (e.g.
> "size+width+height+intervals+value") doesn't seem to be interpreted by
> MapServer since the scalebar settings never get subsequently modified.
> What am I doing wrong? Thanks for any insights!
> Cheers,
John Maurer
Web/Database Applications Engineer
National Snow and Ice Data Center (NSIDC)
University of Colorado at Boulder
http://cires.colorado.edu/~maurerj
+1-303-586-1677
"Without geography, you're nowhere!"
