[mapserver-users] float raster
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Fri Nov 14 09:05:31 EST 2008
Pietro,
Mapserver uses gdal to read grids, and thus, the type of grid is controlled by your gdal configuration options.
The following command line will tell you the formats your install supports:
gdalinfo --formats
More info on the mapserver docs:
http://ms.gis.umn.edu/docs/howto/raster_data
I have successfully loaded a raster grid in the past, and your proposed approach seems fairly straightforward.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Pietro Giannini
Sent: Friday, November 14, 2008 5:58 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] float raster
Hi list,
anyone is experienced about creating raster on-the-fly in a mapscript
application?
I generate a regular grid of georeferenced values (floats) and I want to
display this values as raster, classifying the values using a colorrange.
Can mapserver read an ascii grid as datasource? if not, in your experience
which format is the best?
thanks for any hint.
ciao
..................................................pg
Pietro Giannini
Bytewise srl - Area GIS
41°50'38.58"N 12°29'13.39"E
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
