[mapserver-users] MS 5.2 make error: " yes: invalid option -- f "
Eduardo Kanegae
ekanegae at gmail.com
Sun Nov 16 13:16:58 EST 2008
Hi all,
I´m trying to build MapServer 5.2.0 under CentOS 5 using the following config:
./configure --disable-ignore-missing-data --enable-point-z-m
--disable-gcov --with-freetype=/usr/local/bin/freetype-config
-with-zlib=/usr --with-png=/usr --with-jpeg=/usr --with-xpm=/usr
--with-libiconv=/usr/local --with-gd=/usr/local --with-pdf=/usr/local
--with-agg=/usr/local/src/agg --with-eppl --with-proj --with-threads
--with-geos --with-ogr --with-gdal --without-tiff
--with-postgis=/usr/bin/pg_config --with-ming=/usr/local --with-wms
--with-wfs --with-wcs --with-wmsclient --with-wfsclient --with-sos
--with-curl-config=/usr/bin/curl-config
--with-xml2-config=/usr/bin/xml2-config --with-fastcgi=/usr/local
--with-httpd=/usr/sbin/httpd --with-php=/usr --with-ld-shared 2>&1 |
tee configure.log
But, after some time running make I got:
This message appears just after the line:
yes -fprofile-arcs -ftest-coverage -o php_mapscript.so
php_mapscript_util.o php_mapscript.o mapscript_i.o php_regex.o
-L/usr/src/webmapit/mapserver-5.2.0 -lmapserver -L/usr/local/lib
-lfcgi -L/usr/lib -lxml2 -lz -lm -L/usr/kerberos/lib -lcurl
-lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lresolv -ldl -lidn -lssl
-lcrypto -lz -L/usr/local/lib -lming -L/usr/lib -lpq -L/usr/lib
-ljpeg -lfreetype -L/usr/lib -lpng -L/usr/lib -lz -L/usr/lib -lXpm
-lX11 -L/usr/local/lib -liconv -L/usr/local/lib -lgdal
-L/usr/local/lib -lgeos_c -I/usr/include -lsqlite3 -L/usr -L/usr/lib
-lodbc -lodbcinst -L/usr/lib -lexpat -L/usr/local/lib -lxerces-c
-lpthread -L/usr/local/GeoExpressSDK6/lib/Release
-L/usr/local/GeoExpressSDK6/3rd-party/lib/Release -lltidsdk -lpthread
-lltikdu -L/usr/local/lib -lNCSEcw -lNCSCnet -lNCSUtil -L/usr
-L/usr/lib -ljasper -L/usr/lib -lhdf5 -L/usr -L/usr/lib -logdi31
-L/usr -L/usr/lib -lnetcdf -lpq -L/usr/lib -lpq -lpthread -lm -lrt
-ldl -L/usr/kerberos/lib -lcurl -lgssapi_krb5 -lkrb5 -lk5crypto
-lcom_err -lresolv -ldl -lidn -lssl -lcrypto -lz -L/usr/lib/mysql
-lmysqlclient -lz -lcrypt -lnsl -lm -L/usr/lib -lssl -lcrypto
-L/usr/local/lib -lgeos_c -lpthread -lproj -L/usr/local/src/agg/src
-lagg -L/usr/local/lib -lpdf -L/usr/local/lib -lgd -L/usr/lib -ljpeg
-lfreetype -L/usr/lib -lpng -L/usr/lib -lz -L/usr/lib -lXpm -lX11
-L/usr/local/lib -liconv -L/usr/local/lib -liconv -L/usr/lib -lz -lm
-lstdc++
and then "make[1]: *** [php_mapscript.so] Error 1" is shown.
I already tried to setup CCFLAGS and CXXFLAGS to gcc34/g++34 or
mpicc/mpicxx compilers but the same error happens.
Does anybody has any tip?
best regards,
Eduardo Kanegae
http://anthologis.com
