[MAPSERVER-USERS] Problem TEMPLATE to use getfeatureinfo.html
Tellett
thomas.ellett at statkart.no
Tue Nov 18 07:05:46 EST 2008
Hi Tio,
The 'ttt' template should exist but it should be blank. Open an empty
document
in notepad or textpad etc and save that empty document as 'ttt.html'. Each
layer
in the mapfile has to reference a template in order for that layer to be
considered
queryable by mapserver. If you want your getfeatureinfo results to be
presented in
html format however, you will have to write an html template that fits your
data
(with header and footer if you want multiple results returned). If all your
layers
reference the 'ttt' template, the only output formats for getfeatureinfo
results you
can use are text/plain and text/gml. hope that helps a little,
Tom
Hello
I try to use the example provided by getfeatureinfo.html Mapfish.org
I joined the mail 3 files:
map.js configuration layers with getfeaturesinfo
http://www.nomorepasting.com/getpaste.php?pasteid=21979
websig_norm.map: server configuration wms
I have an error in execution:
Content-type: application / vnd.ogc.se_xml
<? xml version ='1 .0 'encoding = "ISO-8859-1" standalone = "no"? "
<! DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport Version="1.1.1">
<ServiceException>
msReturnPage (): Unable to access file. ttt.html
</ ServiceException>
</ ServiceExceptionReport>
View this message in context: http://www.nabble.com/Problem-TEMPLATE-to-use-getfeatureinfo.html-tp20543794p20558306.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
