[mapserver-users] Failed to show Arabic labels with MapServer 5.2
TC Haddad
tchaddad at gmail.com
Tue Nov 18 22:21:30 EST 2008
Jackey
I've subscribed to your ticket in case I can be of further help down the road.
In the meantime, based on looking at your last example, the labels
without OUTLINECOLOR are pretty good, the one thing I would recommend
further is decreasing your font size by a point or two. This will
minimize the occurence of small fractures that happen when the label
bends around a tight curve (something almost inevitable).
On Tue, Nov 18, 2008 at 5:27 PM, Jackey Cheung <cheung.jackey at gmail.com> wrote:
> Following TC's suggestion, I've done a test.
> With this map file layer:
> LAYER
> NAME "road"
> STATUS DEFAULT
> TYPE LINE
> UNITS METERS
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=localhost dbname=ttt user=uuu
> password=xxx"
> DATA "geom FROM view_road_ar USING UNIQUE
> oid USING SRID=4326"
> LABELITEM "name"
> CLASS
> STYLE
> WIDTH 16
> COLOR 0 0 0
> ANTIALIAS TRUE
> END
> STYLE
> WIDTH 15.8
> COLOR 255 200 64
> ANTIALIAS TRUE
> END
> LABEL
> ANGLE FOLLOW
> ENCODING "UTF-8"
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> TYPE TRUETYPE
> FONT arial
> SIZE 24
> ANTIALIAS TRUE
> POSITION AUTO
> PARTIALS FALSE
> BUFFER 50
> END
> END
> END
> With nothing changed, only change the ANGLE to AUTO and FOLLOW, the
> generated images confirms the different processs of ANGLE AUTO & FOLLOW.
> Then I've done one more test which uses ANGLE FOLLOW, but with OUTLINECOLOR
> removed, then generated image shows "fractured" words.
> mapserver-users at lists.osgeo.org
