[MAPSERVER-USERS] Problem TEMPLATE to use getfeatureinfo.html
Richard LEHAUT
richard.lehaut at crpf.fr
Wed Nov 19 04:42:54 EST 2008
Thank you.
Yes I have a little advanced. I found the location where the file must be
ttt.html record.
As against, the answer is empty and the message server is "X-FirePHP-Data"
response header not found in request response. " I stayed in format text /
html.
I tried to put a format model, but I have trouble positioning. How to use
the default format?
Thank you for assistance tio
----- Original Message -----
To: <mapserver-users at lists.osgeo.org>
Sent: Tuesday, November 18, 2008 1:05 PM
Subject: Re: [MAPSERVER-USERS] Problem TEMPLATE to use getfeatureinfo.html
> Hi Tio,
> The 'ttt' template should exist but it should be blank. Open an empty
> document
> in notepad or textpad etc and save that empty document as 'ttt.html'. Each
> layer
> in the mapfile has to reference a template in order for that layer to be
> considered
> queryable by mapserver. If you want your getfeatureinfo results to be
> presented in
> html format however, you will have to write an html template that fits
> your
> data
> (with header and footer if you want multiple results returned). If all
> your
> layers
> reference the 'ttt' template, the only output formats for getfeatureinfo
> results you
> can use are text/plain and text/gml. hope that helps a little,
> Tom
