[mapserver-users] Create a file "GML" from a layer of type
"annotation".
José María Michia
jose.maria.michia at gmail.com
Thu Nov 20 22:33:01 EST 2008
2008/11/20 Pietro Giannini <pgiannini at bytewise.it>
> Ciao José.
> You can get the WFS layer in a free desktop GIS, like QGis (qgis.org) via
> a default plugin which must be activated, and then export in shapefile.
The problem is that "WFS" works only for layer of type polygon, and
not for layer of type annotation. The need to use an annotation layer,
is because i wish to get labels generalized.
Through the use of "WMS" I've been able in QGIS to show the annotation
layer. But QGIS not allow me to select elements, so that I can not
export them.
> If you need GML use ogr2ogr; qgis also has a converter plugin, but I never
> used - be careful to GML version...
Yes, I use ogr2ogr to convert the GML files to GMT format. But, until
now, i can not obtain the GML that i hope.
> Hope this help
> ciao
> ........................ pg
> Pietro Giannini
> Bytewise srl - Area GIS
> 41°50'38.58"N 12°29'13.39"E
Thanks for your help Pietro
José María
> On Gio, Novembre 20, 2008 14:30, José María Michia wrote:
> > Hi,
> > I want to create a data file, in "GML", starting with a layer of type
> > "annotation" generated by "MapServer" as "WFS".
> > I've only been able to create the file "GML" using LAYER-> TYPE = POLYGON.
> > This does not serve me, because it includes all the elements of the layer.
> > I
> > want a layer that contains only the items that "MapServer" decided that
> > should be labeled.
> > The goal is to use data from the labels in other programs. So, other GIS
> > formats can be fine.
> > Thanks for any advice.
> > José María
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
