[mapserver-users] php mapscript objects in session?
Pietro Giannini
pgiannini at bytewise.it
Fri Nov 21 05:55:10 EST 2008
Ciao Umberto,
excuse me, but your statement has put me in a state of anxiety :)
Currently I'm involved in an ASP.NET C# mapscript developement, and I use
extensively the method of saving mapscript object in session.
Naturally I tested the envirenmnet with a certain number of concurrent
users, and I don't get any strange issue, like accessing to an object of
another session.
Why do you say this is NOT recommended?
ciao .......................pg
Pietro Giannini
Bytewise srl - Area GIS
41°50'38.58"N 12°29'13.39"E
On Ven, Novembre 21, 2008 10:20, Umberto Nicoletti wrote:
> And even if it was possible it is NOT recommended to reuse mapscript
> objects across requests, see my previous post on the "Mapserver Thread
> Safety" thread earlier this week.
> Umberto
> On Fri, Nov 21, 2008 at 10:13 AM, Pietro Giannini <pgiannini at bytewise.it>
> wrote:
>> according to my little knowledge, php cannot store an instance of an
>> object in a session, only primitives variables like strings, integers,
>> floats and arrays (asp.net instead can).
>> for your app you must save the context (mapfile path, the extent, the
>> layers status etc.), and re-instance the map object at each postback.
>> hth
>> ........................pg
>> Pietro Giannini
>> On Ven, Novembre 21, 2008 00:33, Christopher Condit wrote:
>>> Hi-
>>> I'm using ms4w 2.2.7 and I've run into a problem. Ideally I'd like to
>>> create the MapScript map object and store it in the session:
>>> $_SESSION['map'] = ms_newMapObj($getMapPath);
>>> This works fine for the that page, for the first call, but when I
>>> attempt to reference it later I get a PHP error:
>>> Fatal error: Object has an invalid _handle_ property
>>> Am I missing something here?
>>> Thanks,
>>> -Chris
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
