[mapserver-users] WMS don't load
Steve.Toutant at inspq.qc.ca
Wed Oct 1 11:19:42 EDT 2008
Here is an update...
shp2img is now working on both servers. shp2img could not find EPSG file.
setEnv PROJ_LIB was in httpd.conf of apache but was not in my OS
environment variable. After defining PROJ_LIB on the OS ishp2img is
working and create an image.
So I guess shp2img doesn't use apache.....
So, the mapfile is ok. But I still not see the wms image when running the
mapfile from mapServer with
http://ipaddress/cgi-bin/mapserv.exe?map=\ms4w\inspq\map\TutorielStatic.map&mode=map
Maybe there is another environment variable I must define?
Someone knows where I can find a list of variable to set on the OS?
thanks
Steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction des risques biologiques, environnementaux et occupationnels
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081001/2ff44936/attachment-0001.html
